Changing % Infill while the printer is printing.
Posted by scubi
June 04, 2017 01:18PM
Hi Guys,
Please can you tell me if I am able to change % Infill while your printer is printing ?
I know you can make the changes before you start the print, however what code do you use to make the change from 10% to 20% while the printer is printing.
Thanks, appreciate the help.
Re: Changing % Infill while the printer is printing.
June 04, 2017 02:26PM
No.
The tool paths are all fixed at print time. The only parameters you can change are those that don't affect the tool path - things like speed, acceleration, extrusion rate, etc.
June 04, 2017 08:37PM
Your % infill is incorporated in the GCode file when you do the conversion from STL to GCode using your slicer software, it's one of the slicer parameters. You can't adjust it during a print.
Play Bonny!
Soadyheid.
June 05, 2017 01:53PM
Hi Guys
Thanks guys I understand and makes logic sense. Thanks
June 16, 2017 02:26PM
I've been told you can change infill during slicing.
Simplify3D allows your part to print with say 40% and later on(higher up your part) the infill% can be set to any another value.
June 16, 2017 02:42PM
Slic3r can do that, too.
