Best 3d printer to make from scratch June 08, 2017 11:54AM |
Re: Best 3d printer to make from scratch June 08, 2017 12:09PM |
Re: Best 3d printer to make from scratch June 08, 2017 12:15PM |
Re: Best 3d printer to make from scratch June 08, 2017 12:45PM |
Re: Best 3d printer to make from scratch June 08, 2017 02:04PM |
sudarshan
Thanks for the input jinx... I have already gone through the hypercube documentation....it can be a great option if we can improve the frame by adding gussets.....refer to the article on aluminum extrusions on hackaday....however it would be even better if we can use least amount of 3d printed parts in it....Plus I plan to use profile linear guides...any suggestions on that?
As far as I have read...a milled metal plate for xy movement seems to be the best option...but I wish to know more about possible alternatives to metal milling...
Cwaa...thanks for ur input too...the machine seems to have a great potential for being a beginners printer....it would be better If we modify it to use proper lead screws ...ie supported on the both ends...also support to the z axis frame will be an added advantage...I also think it would be better to use proper linear rails than the v slots for better results...what do you suggest?
As far as I have read...the most accepted standard is a core xy with bed z axis. This also helps in enclosing the build chamber to make it fit for printing abs...i read through the thread of Ultra Megan max dominator....it would be cool to have a standardized version of that model for popular use.any ideas on that?
Re: Best 3d printer to make from scratch June 08, 2017 05:23PM |
Re: Best 3d printer to make from scratch June 08, 2017 05:39PM |
Re: Best 3d printer to make from scratch June 09, 2017 09:18AM |
Trexation
I have been doing some research lately and have come across the cheapest way to get a T-slot aluminum frame without compromising quality, just costing time.
The Extrusions:
The extrusions themselves can be purchased from 80/20 through eBay in lots, these lots are parts that they cannot sell for one reason or another and so they sell them in lots by auction. It can easily be 50% cheaper than brand new extrusion of the regular site. Here is a link:
[stores.ebay.com]
The parts are sold in lots and are typically between 12" and 60". I recently bought a lot of stuff around 48" for my next build.
The Fasteners for the Extrusion:
T Nutz is having a large sale and most of the items are more than 50% of the price of 80/20 stuff, it is all OEM
[www.tnutz.com]
General Fasteners:
Purchasing fasteners from the local hardware store can be expensive, I recommend Fastenal, they sell screws and bolts in bulk packages from 25 to 100 for most standard sizes and will ship to the store for free I believe.
[www.fastenal.com]
I am not associated with any of the companies listed.
I hope that this will help you in being able to get the frame parts for your printer in your local area. Also, what is your budget for your 3D printer?
Re: Best 3d printer to make from scratch June 09, 2017 09:36AM |
Re: Best 3d printer to make from scratch June 09, 2017 10:00AM |
Re: Best 3d printer to make from scratch June 09, 2017 10:03AM |
Re: Best 3d printer to make from scratch June 09, 2017 10:07AM |
Re: Best 3d printer to make from scratch June 09, 2017 10:31AM |
Re: Best 3d printer to make from scratch June 09, 2017 11:32AM |
Re: Best 3d printer to make from scratch June 09, 2017 12:42PM |
Re: Best 3d printer to make from scratch June 09, 2017 01:09PM |
sudarshan
Newbob....you are right....the Veblen effect is not worth giving into.....I want to find out the techniques which yield better prints.
like..sturdy frame...good print bed....playless guides...zero backlash screws and nuts or belts..etc...I want to know which companies takled these problems....and how did they do it...and how can we do it...which are the better sources of getting good quality parts at lower prices...what are the substitutes of some costlier industry grade items such as milled stepper brace etc.
dc42...I did a lot of study into the deltas....but they have some inherent problems...with the volume first...trickey alignment, which gives in at the first sight of wear etc...it's although good as a work horse where quality is not that much needed but the quantity of output..plus 3d printed parts at crucial joints is one thing that I wish to avoid...I would be eager to know if you prove me wrong...
Re: Best 3d printer to make from scratch June 09, 2017 03:54PM |
sudarshan
Re: Best 3d printer to make from scratch June 09, 2017 11:59PM |
Re: Best 3d printer to make from scratch June 10, 2017 11:12AM |
Re: Best 3d printer to make from scratch June 10, 2017 11:17AM |
Re: Best 3d printer to make from scratch June 10, 2017 11:33AM |
Re: Best 3d printer to make from scratch June 13, 2017 11:20AM |
Re: Best 3d printer to make from scratch June 15, 2017 05:49AM |
Re: Best 3d printer to make from scratch June 16, 2017 03:35AM |
newbob
I would not dismiss delta design too quickly. As far as I am aware only delta and light weight corexy printers can print at over 100mm/s with decent quality.
Re: Best 3d printer to make from scratch June 16, 2017 08:21AM |
Re: Best 3d printer to make from scratch June 16, 2017 08:39AM |
chriske
newbob
Not a Delta but mine(own design) can print also with that speed and even faster and with a very high perimeter quality.
The printer in the image is a prototype and works perfect. Busy making a larger version this very moment (heatbed 200x300mm), almost done.
, I considered Ultimaker design but overall I think it's performance sits in between speed and precision, and probably 100mm/s is too fast for good precision (especially for larger printers). Please post your results when you get your printer up - I'm curious how it works out.|
Re: Best 3d printer to make from scratch June 16, 2017 09:55AM |
Re: Best 3d printer to make from scratch June 16, 2017 10:04AM |
newbob
chriske
newbob
For a brief moment, after I wrote that delta and corexy 'rule', I considered Ultimaker design but overall I think it's performance sits in between speed and precision, and probably 100mm/s is too fast for good precision (especially for larger printers). Please post your results when you get your printer up - I'm curious how it works out.
) is already in service for a few months now. It outperforms all (about 20)printers by far we've built in the past. The perimeters are superb, no ripple at all, no ghosting around holes.|
Re: Best 3d printer to make from scratch June 16, 2017 11:29AM |
Re: Best 3d printer to make from scratch June 16, 2017 03:22PM |
