When starting print (I have a piezo sensor) it starts print at 0 June 17, 2017 03:21PM |
; CoreXY sample config file for dc42 Duet firmware by Haga. Please use with care. Some of the settings needs to be changed to work with your printer. Read the duetWiki! ;*** [duet3d.com] ; Communication and general M111 S0 ; Debug off M550 PDBotCoreXY ; Machine name (P + anything you like) M551 Preprap ; Machine password (used for FTP connections) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address - If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits M552 S1 ; Enable WiFi M555 P2 ; Set output to look like Marlin ;M575 P1 B57600 S1 ; Comms parameters for PanelDue M667 S1 ; set CoreXY mode ; Machine configuration M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it) M569 P1 S1 ; Drive 1 goes forwards. (Change if motor goes wrong way. Or just turn the motor connection 180 degrees around..) M569 P2 S0 ; Drive 2 goes forwards z M569 P3 S1 ; Drive 3 goes forwards 0 M569 P4 S1 ; Drive 4 goes forwards M574 X1 Y2 S0 ; set endstop configuration (X1 is at MIN end. Y2 is at MAX end. (active high switch = S1, active low switch= S0) M574 Z2 S1 ; set endstop configuration (X1 is at MIN end. Y2 is at MAX end. (active high switch = S1, active low switch= S0) M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation M92 X100 Y100 Z800 ; Set axis steps/mm. Check that the printer really move as much as you tell it. Not more and not less. M92 E138.4:138.4 ; Set extruder steps/mm. Change this to match your extruder. M906 X800 Y800 Z800 E800 ; Set motor currents (mA). Increase if motor is to weak. Lower if motor gets too hot. 800-1000 is good for most. M201 X1500 Y1500 Z300 E4000 ; Accelerations (mm/s^2). The acceleration, speed and jerk is a setting you can alter to try making the printer to print as nice as possible.. M203 X15000 Y15000 Z300 E1500 ; Maximum speeds (mm/min) M566 X600 Y600 Z24 E300 ; Maximum jerk speeds mm/minute M208 X300 Y200 Z300 ; set axis maxima (adjust to suit your machine) M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed) G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Z probe M558 P1 I0 R0.2 F500 X0 Y0 Z1 ; Analog Z probe, also used for homing the Z axis G31 X0 Y0 Z0.1 P700 ; Set the probe height and threshold (put your own values here) ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe ;M557 P0 X15 Y-15 ; Four... ;M557 P1 X15 Y-185 ; ...probe points... ;M557 P2 X285 Y-185 ; ...for bed... ;M557 P3 X285 Y-15 ; ...levelling ;M557 P4 X150 Y-100 ; 5th probe point for levelling ; Thermistors and heaters ;*** You can use S and B parameters to define the parameters of the thermistors you are using. Standard 100k thermistor from E3d is 4388 or 4725. M305 P0 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction ;M305 P2 T100000 B4388 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction ;***Choose if you want to use the M301 or the autotune results and M307 command. Don't use both. M301 H1 P10 I0.10 D100 T0.50 S1.0 ;PID settings for extruder 0 (no need for M301 if using M307) ;M301 H2 P10 I0.10 D100 T0.50 S1.0 ;PID settings for extruder 1 M570 S120 ;Increase to allow extra heating time if needed ;***Use for autotune. Comment out M301 if you do. ;M307 H0 A142 C293.5 D5.4 B0 ;Autotune result for bed ;M307 H1 A588.5 C242.9 D6.7 B0 ;Autotuen result for first nozzle ; Fans M106 P1 T45 H1 ; enable thermostatic mode for fan 1 at temp 45 degrees. Fan turns on when P1(extruder 1) is above 45 degrees. ; Tool definition M563 P1 D0 H1 ; Define tool 0 G10 P1 S0 R0 ; Set tool 0 operating and standby temperatures ;*** If you have a dual-nozzle build, un-comment the following 3 lines ;M563 P0 D1 H2 ; Define tool 1 ;G10 P0 S0 R0 ; Set tool 1 operating and standby temperatures ;*** If you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z0 ; set minimum Z M501 ; Load Config-Override.g that is created using M500 T0 ; select first hot end ;*** Home all G91 G1 Z10 F2000 ; lowers bed 4mm to avoid dragging nozzle over the bed G1 X-340 F3000 S1 ; move up to 340/240mm in the -X (x endstop is MIN) and +Y(y endstop is MAX) directions until the homing switches are triggered G1 X4 F600 G1 X-10 S1 G1 Y240 F3000 S1 G1 Y-4 F600 ; move slowly 4mm in +X and +Y directions G1 Y10 S1 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered G91 ; set movement to relative mode G1 Z5 F200 ; move Z down 5mm G90 ; set movement to absolute mode G1 X145 Y100 F2000 ; move X and Y to probe point. ADJUST X and Y values to get Z probe over target. G30 ; home Z, using values from G31 in config.g G91 G1 Z.3 F200 ; move Z to Z=0 G90 T1 T-1 G10 P1 R140 M140 S60
G21 ;metric values\n G90 ;absolute positioning\n M82 ;set extruder to absolute mode\n M107 ;start with the fan off\n G28 X0 Y0 ;move X/Y to min endstops\n G28 Z0 ;move Z to min endstops\n G29 S1 ;load mesh\n G1 Z15.0 F9000 ;move the platform down 15mm\n G92 E0 ;zero the extruded length\n G1 F200 E3 ;extrude 3mm of feed stock\n G92 E0 ;zero the extruded length again\n G1 F9000\n;Put printing message on LCD screen\nM117 Printing..."
;homeall.g ;homing using a x-MIN, Y-MAX and z-MIN endstops G91 G1 Z10 F2000 ; lowers bed 4mm to avoid dragging nozzle over the bed G1 X-340 F3000 S1 ; move up to 340/240mm in the -X (x endstop is MIN) and +Y(y endstop is MAX) directions until the homing switches are triggered G1 X4 F600 G1 X-10 S1 G1 Y240 F3000 S1 G1 Y-4 F600 ; move slowly 4mm in +X and +Y directions G1 Y10 S1 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered G91 ; set movement to relative mode G1 Z5 F200 ; move Z down 5mm G90 ; set movement to absolute mode G1 X145 Y100 F2000 ; move X and Y to probe point. ADJUST X and Y values to get Z probe over target. G30 ; home Z, using values from G31 in config.g G91 G1 Z.3 F200 ; move Z to Z=0 G90
Re: When starting print (I have a piezo sensor) it starts print at 0 June 17, 2017 09:57PM |
Re: When starting print (I have a piezo sensor) it starts print at 0 June 18, 2017 10:12AM |
Re: When starting print (I have a piezo sensor) it starts print at 0 June 18, 2017 07:37PM |
Re: When starting print (I have a piezo sensor) it starts print at 0 June 18, 2017 10:25PM |
Re: When starting print (I have a piezo sensor) it starts print at 0 June 19, 2017 04:35AM |
