Integrated stepper driver
June 24, 2017 08:50AM
Is there a way to use ramps 1.4 with integrated stepper motor drivers?
Re: Integrated stepper driver
June 25, 2017 02:08AM
That depends on the interface of the stepper. I only know of integrated drivers with SPI or CAN-bus.
With the momentary firmware they are not useable.
June 25, 2017 07:45AM
If the motor's driver accepts step, direction, and enable inputs you should be able to drive them. But do they microstep? There should be dip switches for setting motor current and microstepping ratios. If you don't have any of that you may be SOL. Do you have a data sheet? What does it say?
June 27, 2017 07:43PM
Here is a picture of the connections on the motor
open | download - 2017-06-27-19-37-51.jpg (267.7 KB)
June 27, 2017 09:07PM
That looks like a standard external stepper driver interface
wire like this
NB this image is wrong, there is no 5v on that middle pin of the ramps, its on the right most pin of that connector labeled vcc
Edited 2 time(s). Last edit at 06/27/2017 09:22PM by Dust.
June 27, 2017 09:25PM
From the limited info given
is this the manual?
[static1.1.sqspcdn.com]
June 27, 2017 09:50PM
Yes its an STM23R-2NN from Applied Motion.
June 28, 2017 01:10AM
My question is how do I hook it up to the Ramps 1.4. I'm a machinist and know very little about electronics.
I appreciate all the information from you guyd
June 28, 2017 01:53AM
scroll up 4 posts... to the big image of how to connect it.
Edited 1 time(s). Last edit at 06/28/2017 02:10AM by Dust.
June 28, 2017 07:22AM
OK,
I'll study that image and research it more
Thanks so much you guys, I have a few more questions,
If I am planning to use a 12v power supply for Ramps, should I have a separate 24v power supply for these steppers.
I am only planning to use these steppers for the x and the y axis.
Thanks Again,
I'm a total Noob
Mike
June 28, 2017 05:54PM
Is there an English version of the picture above
June 28, 2017 06:07PM
your kidding right?
all the pins and ports are the same letters...
The only thing that changes is the title
July 01, 2017 11:02AM
Can I run these types of stepper motors on 12 volts?
July 01, 2017 11:43PM
from the manual I posted earlier
Second bullet point, 4th line into the document!
DC Power Source, 12-70VDC
So yes you can. But it will depend on how much torque you need... if your moving a heavy load you may need more voltage
