Help a noob replace a motherboard June 29, 2017 04:04AM |
Re: Help a noob replace a motherboard June 29, 2017 04:53AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Help a noob replace a motherboard June 29, 2017 09:25PM |
Re: Help a noob replace a motherboard June 30, 2017 11:11AM |
Re: Help a noob replace a motherboard June 30, 2017 10:57PM |
Re: Help a noob replace a motherboard July 01, 2017 01:23AM |
Re: Help a noob replace a motherboard July 01, 2017 02:12AM |
Re: Help a noob replace a motherboard July 01, 2017 02:53AM |
Re: Help a noob replace a motherboard July 01, 2017 03:07AM |
Re: Help a noob replace a motherboard July 01, 2017 11:10AM |
Re: Help a noob replace a motherboard July 01, 2017 12:52PM |
Re: Help a noob replace a motherboard July 01, 2017 05:22PM |
Re: Help a noob replace a motherboard July 02, 2017 02:27AM |
Re: Help a noob replace a motherboard July 03, 2017 02:10AM |
Re: Help a noob replace a motherboard July 03, 2017 02:45AM |
Re: Help a noob replace a motherboard July 03, 2017 02:46AM |
Re: Help a noob replace a motherboard July 03, 2017 02:50AM |
Re: Help a noob replace a motherboard July 03, 2017 03:16AM |
Re: Help a noob replace a motherboard July 03, 2017 03:20AM |
am no expert on the mks gen series but you can consider the mks board a single board RAMPS with access to the same pins on the aux ports so what ever works on the RAMPS should work for the MKS.Quote
There still is the question of the thermocouples though. On ramps someone mentioned they were able to use [reprap.org] this to work with but how will they work with MKS?
Re: Help a noob replace a motherboard July 03, 2017 04:03AM |
Re: Help a noob replace a motherboard July 03, 2017 05:10AM |
What do you mean by header? Cant seem to google it. Also red breakout board?
Re: Help a noob replace a motherboard July 03, 2017 05:14AM |
Re: Help a noob replace a motherboard July 03, 2017 05:33AM |
Re: Help a noob replace a motherboard July 03, 2017 05:36AM |
Re: Help a noob replace a motherboard July 03, 2017 05:37AM |
theblindsaint
A small conclusion for now this is my shopping list correct?
[tw.bid.yahoo.com]
[www.gearbest.com]
[www.gearbest.com]
Re: Help a noob replace a motherboard July 03, 2017 05:40AM |
Re: Help a noob replace a motherboard July 03, 2017 05:42AM |
theblindsaint
So I'm also replacing the endstops then. It's probably a good idea to stick with mechanical stops and not optical right? ADo these look right?
[www.gearbest.com]
Re: Help a noob replace a motherboard July 03, 2017 05:52AM |
Re: Help a noob replace a motherboard July 03, 2017 06:01AM |
