Ringing problem?
Posted by Andres_Mikkelson
Ringing problem?
July 02, 2017 05:07PM
Hi guys!
Currently I'm really happy how my mini Kossel prints. Only problem I see left are these tiny ribs on the side of my print. I doubt it's mechanical ringing problem because I don't see or feel any noticeable movement of the frame while it prints. Also, I have vibration dumpers on my steppers.
However, I have noticed that my extruder makes little twitches while running in a long straight line.
Tell me, do I expect too much from my basic machine, or is this something that could be solved?
I'm running on ArduinoMega+RAMPS with DRW8825 stepper drivers.
max x,z,e jerk 15.00 mm/s
min segment time 20000 ms
max acc x,y,z,e 600 mm/s2
x,y,z resolution 200 steps/mm
e resolution 6 steps/mm
Here's also a screenshot of my EEPROM settings in Repetier:
Thanks!
Re: Ringing problem?
July 02, 2017 05:47PM
The main culprit is probably the DRV8825 drivers. See [forums.reprap.org].
July 03, 2017 01:22AM
Is it a typo or do you really print with 6 e-steps/mm?
Do you run it in full step mode? That would explain the pulsing....
July 03, 2017 02:31AM
o_lampe
An excellent point, I should have spotted that before I replied.
July 07, 2017 06:36AM
o_lampe
I'm not 100% sure what you mean by full step mode?
I have re-calibrated my extruder and I get the correct extrusion lenght with 5.95 steps/mm.
July 07, 2017 07:22AM
Did some quick sums and if its 1.75mm filament at 6 steps per mm then 1 step is about 3.2mm extrusion from a 0.4mm nozzle.
Since steppers just move between steps you only extrude when moving then just get leakage when it stops. So if the number of steps is low you could get extrusion as pulses instead of a smooth flow.
Speed also has an influence, but I would think you want enough steps and a good enough speed to try and get the moving time longer than the stopped time. Increasing the print speed should help. What is your print speed?
Bowdens are probably less affected as there is some damping due to the filament length.
July 07, 2017 02:21PM
I have been printing at 30mm/s. Doubling the speed solved the problem.
Thanks guys!
July 08, 2017 01:50AM
Andres_Mikkelson
o_lampe
Full step is the opposite of microstep. Usually with 1/16 microstepping your steps/mm are around 90-100.
Either your drive gear diameter is very huge or you haven't set the microstepping jumpers correctly.
Printing faster just blends the problems into one big problem
