Launching a new build plate
Posted by andornot
Re: Launching a new build plate
July 14, 2017 03:17PM
andornot
Having problems with my website so i am unable to upload pictures to the beds, 8 inch £7.50 + vat and 12" £14.50 + vat and delivery. PM me if you want to order them and i will sort it out.
OK thanks. Will be a couple if weeks before I'm ready. Will let you know when I'm ready
July 16, 2017 03:42PM
The link to my beds is:
[www.andornot.co.uk] 12" square AndOrNot build plate
[www.andornot.co.uk] 8" square AndOrNot build plate
Regards
Andrew
July 16, 2017 04:16PM
its good to see it up am a convert, its proven itself to be brilliant with PLA more reliable than kapton tape and cleaner than gluestick.
July 16, 2017 05:03PM
Very interested in this. It appears from the photo that the price includes adhesive. Is this correct, please?
Edited to add: Also, has it been tested with David Crocker's IR sensor? Did it work?
Thanks.
Richard
Edited 1 time(s). Last edit at 07/16/2017 05:22PM by RGN01.
July 17, 2017 01:47PM
Any news if this works with David's IR Sensor? If yes, I would be happy to get one since I have some issues with PrintBite and ABS...
July 17, 2017 02:01PM
Not tried it for sure, but put a black substrate under it, and I can see no reason why not, its fairly transparent and no graphics to affect the consistency of readings across the surface.
Simon Khoury
Published:Inventions
July 17, 2017 04:38PM
I have send a sample David to try with his IR sensor, hopefully soon he will give you all feedback.
@rgn01 it does include an adhesive like Lokbuild and Printbite.
Edited 1 time(s). Last edit at 07/17/2017 04:38PM by andornot.
www.andornot.co.uk, selling new products, including smoothie boards and other useful parts for 3D Printers:
AndOrNot buildplate launched, available in 6 inch, 8 inch, 12 inch and 17 inch square introductory discount code "20reprap"
And Or Not Build Plates
July 18, 2017 03:48PM
@ Andornot
wondering about this " if you require custom graphics " could be fun personalising the surface but how much for example would this add to the cost of a 8" plate
Edited 1 time(s). Last edit at 07/18/2017 03:57PM by jinx.
July 18, 2017 05:08PM
@ jinx, maybe you could print your own personalised surface with paper or another material and stick it to the back of my print bed material and then stick a 3m double sided adhesive to this, also available from my website in 8 inch and 12 inch.
Just an idea, i will give a try and post the outcome.
Andrew
July 20, 2017 04:58AM
Well I just about completed my review with PLA rebel review I've not had a PLA print fail once out the 10 or so prints if you looking for at remote printing and need a reliable surface this is it, if your print fail it want be because adhesion to the bed. and thanks to Andrew and the team for the opportunity to review this build plate
July 20, 2017 06:03AM
Great review Jinx. smiling smiley
Simon Khoury
July 20, 2017 08:18AM
AndorNot
that aint how I imagined it work a paper print attached to glue side would/possible look crap and distorted and loose the transparency as a whole, am googling how T shirt graphics applied ! my thinking is/was that you take the blank surface then apply the graphics then the glue backing that leave clean sharpish image,, the killer downside to it is if the ink cook and bubble creating an uneven surface.
IS THERE ANY T-shirt makers in the house!
this vinyl looks interesting but damn intensive on details.
Edited 1 time(s). Last edit at 07/20/2017 08:56AM by jinx.
July 20, 2017 12:52PM
Depending on the thiknees of your build surface you may feel the lines underneath
July 23, 2017 01:40PM
Jinx thanks for the review of the printer build plate.
July 26, 2017 02:26PM
I am offering an Introductory offer on my bed material for the Reprap community of 20% off, discount code: "20reprap"
Links below to the bed plates
12" AndOrNot Build Plate
8" AndOrNot Build Plate
July 26, 2017 05:58PM
Looks great! Any chance on an instructable on how to cut it? Is it similar to acrylic or glass where you score and snap?
Also, have you found any materials that won't print on this? The list of materials sounds extensive enough for day to day printing anyway so will be buying this regardless
How do you clean this surface? Can you use acetone?
Edited 1 time(s). Last edit at 07/26/2017 08:15PM by Origamib.
July 26, 2017 06:01PM
jinx
AndorNot
Preferably you would want to put it directly to the plastic and then apply adhesive. Have you considered water transfers? I use them for printed stuff all the time.
July 27, 2017 04:15AM
Origamib
thats sounds like a belting plan " like the old airfix graphs or those temporary tats." googling right now thou am faced with a wall of hydro dipping at the mo. If you got a link too an how to make custom graphics I really appreciate it thanks.
No fan of hydro dipping its an ecological disaster in the waiting if it ever takes off "we be drinking petroleum as clowns throw the waste in the sinks... needs more cofffeee
"How do you clean this surface? Can you use acetone?"
unless Andrew say differently , using ABS be handy to have some form of acetone or the likes around with a flat palette knife... PLA fine come away clean thou cheap heavy filled pigment filament can leave stain.
July 27, 2017 04:34AM
To clean the bed do not use acetone, alcohol based fluid are ok to use. I need to write a blog on website on its use, if you have any questions just ask.
Andrew
July 27, 2017 05:10AM
AndorNot
its been/ongoing pleasure, been a real eye opener, "I thought these print surfaces was just a rich man gimmick!"
random cubes over the week belting first surface "well look closer at the left pic, but that was my failure rather than the surface" I just wouldn't get that repeatability with gluestick or Ktype first time everytime.
just waiting on on fila sample to test others.
Edited 1 time(s). Last edit at 07/27/2017 05:12AM by jinx.
July 28, 2017 04:48AM
jinx
Origamib
I use water transfer sheets from Amazon. You just print on them from your normal inkjet printer and then spray them with clear lacquer to stop the ink running. Cut it out, pop it in water and then slip away from the backing on to your desired surface. seal again with lacquer to keep it in place. 3-5 coats of lacquer makes a really strong surface. If this was your print surface I would try to do this to the back of the print surface and then apply the adhesive instead of the final coats of lacquer. Then stick it to desired print bed material (aluminium, glass etc).
July 28, 2017 08:32AM
All build plates surfaces are much too expensive, and over glamorized. I purchased a similar surface for my 3D Printers and it is difficult to get anything to stick to it.
I cover my expensive build surface with Vinyl Transfer Paper Tape, similar to blue painters tape comes in 300yard rolls. With widths that will cover any build plate in one pass.
And it comes with different adhesion low, medium and high tack, have a Vinyl Transfer Tape with a plastic covering of different styles and lengths.
The Sample tape set come with a mere 10 yards of tape for your testing without having 300 yards of tape you may not use.
videos showing how easy it is to use
At a cost of .10cents per covering, which last for dozens of prints.
Installing Vinyl Transfer Paper (video shows old aluminum build plate)
[youtu.be]
Will Vinyl transfer paper Hold my Part
[youtu.be]
Edited 3 time(s). Last edit at 07/28/2017 08:54AM by Roberts_Clif.
July 28, 2017 10:34AM
Hi Roberts_clif,
This sounds interesting what can you print on it and what temperatures do you use?
If a print surface is easy to use, lasts a long time and is cheap enough like AndOrNot surface promises to be then it's worth it.
I use printbite currently and it's not a case of replacing it every few dozen prints I've had a piece going for 2 years. So at £20-£30 its not bad value for zero hassle for years.
But I'm keen to see what the alternatives are.
Edited 1 time(s). Last edit at 07/28/2017 10:44AM by DjDemonD.
Simon Khoury
July 28, 2017 12:49PM
Nice idea, but is the maximum temperature the tape can handle?
Roberts_Clif
[youtu.be]
[youtu.be]
July 28, 2017 01:43PM
andornot
Have had more failed prints in one day, with a build plates surface than I have ever had on the paper surface currently using.
Will use what works. And As you can see in my video vinyl transfer paper works well is inexpensive, and you can see it holds very well.
What is the max temperature for Painters Tape. Have never seen it on any spec sheet an this material is used daily.
Edited 1 time(s). Last edit at 07/28/2017 01:47PM by Roberts_Clif.
July 28, 2017 02:27PM
I am interested in this material as i have a range of bed materials i sell through my website, where would i purchase it from to give it a go.
I am currently testing other materials, my aim is to drive down the prices of add-ons and consumables and make it more affordable for everybody.
July 28, 2017 02:45PM
Would you mind sharing a brand, or even a link to by this tape? I made a quick search and it seems to be too many hits to pick one? Perhaps they are all the same, but just to make sure... I am from Germany if it matters, but would gladly order from UK as-well.
July 28, 2017 03:13PM
Have not tried all can't say, I do know that all Blue Painters Tape is not the same. Bought some painters tape once, it fell off the walls before I could paint.
However most Vinyl Sign retailers sell a sampler set of their material at a fraction of the cost. This includes the Transfer Tapes.
They sell 10 yard sample rolls.
RTape
Edited 4 time(s). Last edit at 07/28/2017 09:04PM by Roberts_Clif.
July 29, 2017 04:40AM
origamib
Thanks for that, hope to give that a go soon
July 30, 2017 01:52AM
jinx
AndorNot
Maybe something like THIS works for you? Just an example for inspiration smiling smiley
Siggi
Geeetech I3 Pro B 8mm Acryl - Mega 2560 - Ramps 1.4 - TMC2100 - MK42 - E3DV6-Clone 0,4 - SSR 522-1dd60-40 (A-Senco) - Marlin RC8Bugfix 26.12.2016 - Repetier Host - Windows 7 64 Bit
Vulcanus mit Linearschienen
Anycubic i3 Mega
