Launching a new build plate
Posted by andornot
Re: Launching a new build plate
July 30, 2017 02:38AM
siggi66
Maybe something like THIS works for you? Just an example for inspiration smiling smiley
thanks for that, I do think between you and origamib we have a plan for graphic transfer.
July 30, 2017 05:31AM
The biggest advantage i see is: You don't have to work with dangerous chemicalsspinning smiley sticking its tongue out
Siggi
Geeetech I3 Pro B 8mm Acryl - Mega 2560 - Ramps 1.4 - TMC2100 - MK42 - E3DV6-Clone 0,4 - SSR 522-1dd60-40 (A-Senco) - Marlin RC8Bugfix 26.12.2016 - Repetier Host - Windows 7 64 Bit
Vulcanus mit Linearschienen
Anycubic i3 Mega
July 31, 2017 04:40PM
6 inch and 17 inch build plates will be in stock next week, they are available for backorder now.
August 04, 2017 09:40AM
great work.. looking nice
August 10, 2017 01:49AM
Not every day I get to print on an Xwing,,, A test for the larger one to come wanted to see if the thermoplastic sheet or 3M distorted/dulled the image or colour in any way " its all fine bar the size " see how that holds up to the heat, want be a problem if you still use a cold bed [www.youtube.com] but the days of single colour, bland print surface is over!.
think it may just do for a cold bed, only thing to do is watch the ink cook/boil at 55C. see the prep here
Edited 6 time(s). Last edit at 08/10/2017 09:13AM by jinx.
August 16, 2017 03:02PM
Jinx thanks for trying out the prints underneath andornot's bed material, they look a promising technique to customise your 3d printer. I am looking into sourcing a high temperature print material, i will keep you posted.
Regards
Andrew
