Re: Flexible build plate suggestions June 07, 2018 08:01AM |
Trakyan
It's not so much about bending over time, if my understanding is correct it's more about how far it can bend or flex before it deforms permanently. So using other kinds of steel you'll just need to be careful with how much you flex them.
Re: Flexible build plate suggestions June 14, 2018 05:59PM |
Re: Flexible build plate suggestions June 15, 2018 02:36AM |
Re: Flexible build plate suggestions June 15, 2018 02:55AM |
Re: Flexible build plate suggestions June 15, 2018 05:17AM |
Re: Flexible build plate suggestions June 15, 2018 06:31AM |
Re: Flexible build plate suggestions June 15, 2018 07:24AM |
Re: Flexible build plate suggestions June 15, 2018 07:26AM |
JoeK1973
Looks great! I would definitely be interested if it is possible to make one for the standard MK2/3 heated bed (213*213).
Although it should be self-evident that placing a piece of metal on a hot surface makes the piece of metal hot too, o_lampe is right. People can be silly.
Re: Flexible build plate suggestions June 15, 2018 08:15AM |
andornot
JoeK1973
Does this bed require the corners cutting off?
Re: Flexible build plate suggestions June 19, 2018 05:44AM |
Re: Flexible build plate suggestions June 19, 2018 07:53AM |
Re: Flexible build plate suggestions June 19, 2018 08:23AM |
Re: Flexible build plate suggestions June 19, 2018 04:42PM |
Re: Flexible build plate suggestions July 26, 2018 04:12PM |
