do people prefer tiled heaters for simplicity in construction and cost, or do people prefer a large heated bed with holes in it to provide for vacuum? the idea hear is to use a raised heater bed, with air space in between to act as an accumulator for a week vacuum that is generated by exhaust fans. there should be enough pull to keep a paper kapton tape conveyor on strait and flat. this design is in the works and this video just shows the base-plate section. it took some time to figure out, the previous versions would crumble and would break just pulling out of the tool fixture . this is the first base i have designed, that can endure ruff handling, and also be laser cut.
i thought it would be easy to build a base to show what i was talking about, but it took a long time to come up with a solution that held the tiled copper heaters in place. it would also work for a solid heated bed with holes in it for vacuum. here is a video showing what kind of heater can be constructed with spaces in between for a vacuum to pull down on the conveyor belt. also it shows how rivets would be used to support the bed, and in this case resistors that i have heated to over 150dec
specifically do people mind tiled heaters, or do people want the full size heated bed with 1 copper sheet for a conveyor system?
any constructive comments welcome.
here is the wiki page for the project.
www.reprap.org]
edit:: ya, video is sideways. sorry taken on my iphone.... fix later...
Edited 2 time(s). Last edit at 05/17/2011 07:24AM by jamesdanielv.
