What is the output on the extruder controller?
Posted by HereinCS
March 22, 2011 12:17AM
I have a makerbot electronics set as well as a reprap verson 6 coming in. I'm trying to understand how the extruder board functions. It takes a temperature sensor in, then output some voltage right? How much voltage does it put out and at what current? Can this current drive a solid state relay? Thanks.
VDX
Re: What is the output on the extruder controller?
March 22, 2011 04:57AM
... it's switching the 12V over the MOSFET's to the outputs.
The maximum current is defined by the MOSFET's (with cooling more) and the capability of your power source.
I think you can apply 24V instead of 12V too ... be sure there's nothing limiting the max. voltage, as capacitors, voltage regulators or such ...
Viktor
