Simplify3D retraction before first layer July 28, 2017 05:31AM |
G28 ; Home all axes ; Starting script end G92 E0 G1 E-2.5000 F1800 G1 Z0.180 F1000 ; layer 1, Z = 0.18
Re: Simplify3D retraction before first layer July 28, 2017 05:57PM |
Re: Simplify3D retraction before first layer July 29, 2017 09:13AM |
Re: Simplify3D retraction before first layer July 29, 2017 09:41AM |
Re: Simplify3D retraction before first layer July 29, 2017 11:40AM |
Re: Simplify3D retraction before first layer July 29, 2017 07:02PM |
M107 G4 P2000 ;pause for paneldue G28 ;home M190 S80 ;heat bed M109 S130 ; set extruder temp G32 ;autocalibration - set grid on/off in bed.g M109 S223 ; set extruder temp M564 S0 ;disable movement limits G1 X40 Y-168 F3000 ;move to front G1 E20 F100 ;extrude 20mm slowly G4 P1500 ;pause G1 Z1 F3000 ; lower to clip off filament excess M564 S1 ;restore movement limits M220 S100 ;optional speed control default 100 ; Filament gcode G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion G1 E-1.00000 F3000.00000 G1 Z0.500 F7200.000 G1 X-24.339 Y20.264 F7200.000 G1 Z0.300 F7200.000 G1 E1.00000 F3000.00000 G1 F1200
Re: Simplify3D retraction before first layer July 30, 2017 01:58AM |
Re: Simplify3D retraction before first layer July 30, 2017 01:11PM |
Re: Simplify3D retraction before first layer September 20, 2017 09:32AM |
DjDemonD
The first few commands are my start gcode, then after setting the units, G1 E-1 then the move to the first printing coordinate and then the unretract.
Does the S3D gcode also have an unretract, if so its not really a problem is it?
