I'm planning to build a resin 3D printer with LCD instead of a standard projector.
I will use a 24 inches 4K LCD screen, but I need to decide which resin to pick.
I saw daylight resins, which harden when white light hits it, (the one used by ONO - the smartphone SLA 3d Printer), but I find the color choice very limited.
I read that you can replicate the projector's DLP by replacing the LCD backlight with an UV LED matrix, but some users say that the LCD panel will not let UV rays pass through it and harden the resin.
What would I need to do in order to successfully use a monitor with UV backlight as hardener for the resin?
