Re: PCB Effector with embedded sensor August 07, 2017 06:42PM |
Mutley3D
@leadinglights, im sure im reading your comment incorrectly. Your not saying brass is magnetic are you. Am I correct interpreting that your iron cups were disrupting a magnetic field reducing its strength?
Re: PCB Effector with embedded sensor August 07, 2017 07:19PM |
leadinglights
Mutley3D
That's what makes it so odd. Iron is magnetic but a magnetic field finds it easier to pass through iron so it goes up the sides of the cup. This really needs a drawing or even better, a video but the effect is that the ball clings to one side for the first maybe 1/10 of a mm then the next 2 or so mm riding up the side - the pull gradually weakens until it disconnects completely. The iron cups were not reducing the magnets strength, just it's effectiveness - like a strong army pointing it's weapons in the wrong direction.
Mike
Damn! I will have to do some drawings.
Re: PCB Effector with embedded sensor August 08, 2017 01:39AM |
Re: PCB Effector with embedded sensor August 08, 2017 02:02AM |
Re: PCB Effector with embedded sensor August 08, 2017 02:30AM |
Re: PCB Effector with embedded sensor August 08, 2017 03:55AM |
Mutley3D
A good grade cup magnet of correct size to fit the ball, can have advantages over the alternative cylinder magnet (in rod end), given the size constraints in the application. Inferior parts will always result in poor performance.
Re: PCB Effector with embedded sensor August 08, 2017 04:55AM |
i'd say they easily hold at least 0.5kg individually ball to cup. It almost feels closer to 1kg. I can do a short vid of an experiment to demonstrate when i get a few moments to determine what force they do hold with. so just to clarify, I offer two options, both using Haydns ball studs.|
Re: PCB Effector with embedded sensor August 08, 2017 05:23AM |
Re: PCB Effector with embedded sensor August 08, 2017 06:04AM |
Re: PCB Effector with embedded sensor August 08, 2017 07:34AM |
Re: PCB Effector with embedded sensor August 08, 2017 08:55AM |
chris33
you get rid of movement with traxxas ball ends with springs
Re: PCB Effector with embedded sensor August 09, 2017 02:07AM |
DjDemonD
I've thought about that the Haydn system does leave a tiny amount of delrin on the cup in the arm between the steel ball and magnet. But I'm not sure I'd want to fill it with anything abrasive. Would oil and graphite powder be magnetic? How about graphene? I haven't come up with a use for the new wonder -
substance in 3d printing yet.
Re: PCB Effector with embedded sensor August 09, 2017 02:26AM |
Re: PCB Effector with embedded sensor August 09, 2017 03:28AM |
Re: PCB Effector with embedded sensor August 09, 2017 04:22AM |
o_lampe
......................... The cup pulls on the ball from all different angles ( upto +/-45° )
As soon as the forces got out off balance, the ball wanders in one direction.
Re: PCB Effector with embedded sensor August 10, 2017 03:18AM |
Re: PCB Effector with embedded sensor August 10, 2017 05:38AM |
Re: PCB Effector with embedded sensor August 10, 2017 05:57AM |
Re: PCB Effector with embedded sensor August 10, 2017 06:33AM |
Re: PCB Effector with embedded sensor August 10, 2017 07:31AM |
Re: PCB Effector with embedded sensor August 10, 2017 04:05PM |
