Repetier speed max out at 50mm/s September 11, 2017 06:05AM |
Re: Repetier speed max out at 50mm/s September 11, 2017 09:50AM |
Re: Repetier speed max out at 50mm/s September 11, 2017 10:24AM |
Re: Repetier speed max out at 50mm/s September 12, 2017 09:18AM |
Re: Repetier speed max out at 50mm/s September 12, 2017 11:26AM |
Re: Repetier speed max out at 50mm/s September 13, 2017 03:41AM |
Re: Repetier speed max out at 50mm/s September 13, 2017 04:59AM |
Re: Repetier speed max out at 50mm/s September 13, 2017 06:30AM |
Re: Repetier speed max out at 50mm/s September 13, 2017 01:08PM |
Ludvig
The, for me, curious thing is that if I fake the microsteppingin in Repetier (basically tells it to move the motor further to move a mm), the printing head maxes out.
But if I only set the maximum speed, there seems to be a very distinkt 'lock' at 50mm/s (give or take some).
I can set a lower value and that works.
I have tried only with the graphical move commands in the Repetier soft.
Ludvig
Re: Repetier speed max out at 50mm/s September 15, 2017 02:26PM |
Re: Repetier speed max out at 50mm/s [Solved] September 16, 2017 12:28PM |
