Survey on Beds sizes for build plates
September 13, 2017 06:46AM
My webside currently sells a range of different build plates in a small range of sizes 6, 8, 12 and 17 inch square for AndOrNot build plate, PEI and Lokbuild.
I am trying to determine what people want in build plate sizes as there maybe cost savings for the end user if i say offer 15 inch square rather than having to pay for a 17 inch build plate. The size changes for Lokbuild are out of my control as i am a reseller for Lokbuild, but AndOrNot and PEI build plate can be cut whatever size is more economical for the users.
Please reply to this thread and state the size of bed require and from the responses, i will produce a matrix of sizes and costs to better meet the market demand.
Edited 1 time(s). Last edit at 09/14/2017 05:26AM by andornot.
www.andornot.co.uk, selling new products, including smoothie boards and other useful parts for 3D Printers:
AndOrNot buildplate launched, available in 6 inch, 8 inch, 12 inch and 17 inch square introductory discount code "20reprap"
And Or Not Build Plates
Re: Survey on Beds sizes for build plates
September 13, 2017 07:22AM
I have 100mm circular, 330mm circular and 200x300mm.
Simon Khoury
Published:Inventions
September 13, 2017 08:07AM
I have 330mm circular, 210x210, and approx. 300x200.
September 14, 2017 03:14AM
the mk3 alu 213x213 mm here
September 14, 2017 12:35PM
My home printer, as well as the one I use at work, are both pretty close to 12 inch square.
September 14, 2017 01:46PM
300x300 square
September 14, 2017 02:13PM
What do you define as "build plate"?
Bed ---- the flat surface required for good print?
Glass, Aluminum, other
Heated
How is your build sheet held to/down to bed?
my size 300mm x 300mm glass heated
I print directly on glass
confused smiley
September 14, 2017 04:02PM
My build plate is stuck down with 3m double side tape. If you only print on glass then this thread does not apply, although in the future you may want a PEI or our own build plate.
September 19, 2017 03:10AM
250x320mm cast aluminum plate with PEI sheet
Self-sourced Mendelmax 2.0-based Reprap Machine -- Ramps 1.4 & Mega 2560 -- DRV8825 (Z@1A, [email protected], [email protected], E@1A) -- genuine E3D v6 direct setup -- 350W custom silicone heated bed -- ABS 1,75mm -- Marlin 1.1.0-RC7 -- Cura 15.04.6
September 23, 2017 06:09AM
Andornot, please stop reposting your "survey" in every subforums, it's spam. I'm leaving just this one topic.
