Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 25, 2017 05:35AM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 05:38AM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 10:30AM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 10:40AM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 10:53AM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 03:01PM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 04:04PM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 06:00PM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 06:33PM |
prot0typ1cal
Garolite.
There's plenty of types for consideration.
G7 high temp, flame retardant has the highest thermal resistance, while G11 offers the highest thermal insulation.
G10/FR4 you can get with ground precision flat surfaces, with comparable tolerances to MIC-6 or ATP-5.
I'm using 1/2" CE to insulate under my heated bed. Though you will still get heat creep, that is, the garolite will eventually heat up.
If you want a true insulator, ceramic is the best.
Calcium silicate sheets typically starts at 1/2" thick (40lb per cu ft is best), while ceramic fiber sheets are less prone to cracking with normal handling and are available down to 3/16" thick.
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 26, 2017 08:02PM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 27, 2017 07:10AM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 27, 2017 10:20AM |
klcjr89
I have ordered the 1/4" thick precision ground Garolite, which will be a 1.32 lb weight reduction over Mic-6 of the same thickness. The flatness tolerance is equivalent to Mic-6.
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 27, 2017 10:28AM |
klcjr89
Where are you seeing a flatness tolerance? The McMaster page only shows thickness, although I'm sure flatness will be quite good.
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 27, 2017 12:47PM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 27, 2017 02:18PM |
Re: Looking for a specific alternative to Mic-6 bed plate, requirements listed. September 27, 2017 05:41PM |
