What are the considerations should be cared for when building a large 3d printer September 25, 2017 11:30AM |
Re: What are the considerations should be cared for when building a large 3d printer September 26, 2017 12:03PM |
Re: What are the considerations should be cared for when building a large 3d printer September 26, 2017 07:30PM |
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 05:11AM |
, I currently started working in a firm with 11 FFF machines while the country here isn't flexible with importing printers (the same problem doesn't exist for spare parts luckily) , so the thought of buying such one will be a little bit tricky here...
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 05:52AM |
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 06:03AM |
cozmicray
Read:
My coreXY design is progressing to the build stage
[forums.reprap.org]
An Almost Reliable, High Precision, 3D Printer: Son of MegaMax
[www.instructables.com]
and
Mark Rehorst's Tech Topics
[drmrehorst.blogspot.com]
Then read them again take notes and heed
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 09:25AM |
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 01:47PM |
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 02:08PM |
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 06:24PM |
Re: What are the considerations should be cared for when building a large 3d printer September 27, 2017 08:51PM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 05:42AM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 09:05AM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 09:17AM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 10:21AM |
davew_tx
DD: . started in your signature, to the blog, watched videos, then found the forum.
I can't believe you did a whole printer, in the public eye, and kept your sanity. (trolls are rare in here for sure) kudos. I just can't find time computer for writeups.
I wouldn't change a thing. plus you gave the data, although i'm not sure it's needed. Pictures are great. Love the Z.
when i did a cable driven core xy, i swore off that style. it was cool but slippage killed it.
I have that same 12x12 line level pad and I'm worried about my 1/4" mic6 plate warping because it's like 20x17 or something. I haven't cut it down yet.
I think the center hot spot will make the plate a bowl shape. I'll do your ssr power safety idea, but since there is a thermistor embedded into the orange matting, I wonder if it can fail.
i'm also thinking of just doing chamber heating and use normalization time to get it all up to 60C or so. my results in the past with ABS in the 40's had issues, and I think more temp is better.
i starting to getting my head back into 3d printing, back from routing. I think i've said that twice in the last year........
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 11:00AM |
davew_tx
You still haven't said what you want this machine to make.
Can you share the end part needs?
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 11:23AM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 11:27AM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 11:29AM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 11:49AM |
Re: What are the considerations should be cared for when building a large 3d printer September 28, 2017 01:15PM |
