Quick question on this board.
Posted by DjDemonD
October 11, 2017 09:39AM
? Melzi board from cr10.
Are the 2 pin endstop connectors GND and SIG? Or is one VCC?
Trying to advise how to connect our piezo sensor which has 3.3v-5v in, SIG, GND and works NO.
Edited 3 time(s). Last edit at 10/11/2017 10:27AM by DjDemonD.
Simon.
[www.precisionpiezo.co.uk] Accurate, repeatable, versatile z-probe plus piezo discs, endstop cables, pt100, 50w heaters. PT1000 cartridge sensors plug straight into duet boards and others.
Published:Inventions
Re: Quick question on this board.
October 11, 2017 06:28PM
[ cynical mode ]
And you want us to do your work for you?
Maybe a incentive like a free probe to the best working solution would help to motivate us who don't get payed for this.
[ /cynical mode]
two pin endstops are normally gnd and signal.
Can find no information on this other than a name "Creality Cr-10 3D Printer Motherboard"
I would take a good look at the USB/vreg jumper. As an educated guess the pins are probably: 5v from vreg, input to main board 5v bus, 5v from usb. If so you could make up a two pin connector to replace the jumper, that takes power, and connects it to usb or vreg just like the jumper did. (or just solder a wire to the jumper)
Edited 8 time(s). Last edit at 10/11/2017 06:51PM by Dust.
October 11, 2017 07:34PM
[serious mode] Where would you like your free sensor sent?[/serious mode]
I did find an entry on thingiverse where someone called this board a s-melzi but nothing else.
Edited 1 time(s). Last edit at 10/11/2017 07:36PM by DjDemonD.
Simon.
