Change Marlin Z_MAX_POS with gCode ?
Posted by DaveOB
October 12, 2017 04:05PM
In my Marlin config I have the setting :
#define Z_MAX_POS 300
I am extending the Z axis to 400mm temporarily for a print.
Is there a gCode that I can use to change the Z_MAX_POS to 400 without having to reflash the Arduino ?
Re: Change Marlin Z_MAX_POS with gCode ?
October 12, 2017 04:58PM
How can you temporarily grow your printer 100mm?
Why not just set it at 400mm and leave it there.
October 12, 2017 05:01PM
Hi
Because my Z axis at 300mm fits in my heated enclosure for ABS prints.
Not very often that I want to increase the Z to 400 or 600, so prefer to change it with gCode if possible
October 12, 2017 06:30PM
There was a gcode defined to set the axis length many years ago (M208), but according to the Gcode wiki at [reprap.org] Marlin uses M208 for a different function.
October 13, 2017 12:35AM
Floyd
it's a home modified i3 design that has makerslides and threadbar on the Z axis that I can change up to the limit of the threadbar ( 900mm )
