extruder can't work
Posted by ahmed powera
extruder can't work
October 29, 2017 05:59PM
hi
i have extruder with fan not work
i dont now why maybe the confugiration
i have this version framware
Marlin-1.1.x
thank you
Edited 1 time(s). Last edit at 10/29/2017 06:06PM by ahmed powera.
Re: extruder can't work
October 29, 2017 06:48PM
almost shocking ! that you posted the same Q without adding more details. things like board, you sure you wired it right ?
you got as far as installing the correct values in firmware? able to take pics?... where you wire the fan too.
October 29, 2017 10:09PM
Power the fan from 12v see if it work then.
October 30, 2017 11:24AM
new the fan are worked but the extruder doesnt work am using D10 it not heating
but when i test them with converter it work
the problem D10 not have power
and when i want to preheat it give to me a message is "Err:MAXTEMP printer halted please reset"
in the info screen it write tempurature are "330/0"
Edited 2 time(s). Last edit at 10/30/2017 11:29AM by ahmed powera.
October 30, 2017 06:04PM
Your thermistor is either shorted or setup incorrectly. It will not allow you to heat till this is fixed. (ie reads room temperature when not heated)
