How to calibrate z=0
Posted by Marcus.Couceiro
November 26, 2017 02:08PM
Hi Guys,
I´ve been struggling with this for a while and must confess my patience is gone.
I am trying to calibrate the Z axis but I am missing something. The way I try to do this now is to put a "caliper" (it´s an old PCB board (1.65 mm thickness) which has a wire attached to it and also connected to the ground of Z-Min connector. The extruder has an alligator clip with a Wire connected to it and to the signal of Z-Min connector. So, sending a M119 I can see if the circuit is closed) and lower the extruder until it touches it then I send a G92 Z1.65 command and then M500.
Next, I home Z-Axis and send it to z=0.4 using G0 Z0.4 I was expecting it to be exactly 0.4mm from the bed but it crashes all the time.
I am using Marlin 1.1.6 and Repetier as host.
Could you guys teach me how to do it correctly?
Regards,
Marcus
Re: How to calibrate z=0
November 26, 2017 02:15PM
“Next I Home the z axis”
What firmware? Do you have an end stop?
In most firmwares, homing an axis equates to moving it to the endstop (that’s a known position) and then loading the value configured with M851 as the current Z.
That completely overrides all you are doing with G92, which would not be saved to EEPROM anyway.
November 26, 2017 02:50PM
Agreed. when you start a print it tries to home X Y and Z before printing.
November 28, 2017 12:39PM
Hi Guys,
Thanks for the answers. I am using Marlin 1.1.6 and I have a Endstop configured as Z-Max.
Since I shall not perform a Z-Home, what should be the operational sequence? Should I do as follow?
  • Send G92 when Z is above the table, at a known distance;
  • Send M500;
  • Start printing without homing Z-Axis;
Regards,
Marcus
November 28, 2017 01:01PM
If you home to Zmax the bed or X axis has to go all the way down/up before returning to the printing position. If there is any error in your Z axis calibration sending the Z axis all the way back to z=0.4 may miss the mark completely.
The normal way is to put the Z limit switch at Z=0 or close to it. Then you home to that position which is either the print position or close to it and the calibration of the Z axis won't matter much, at least as far as getting the first layer to stick is concerned.
Son of MegaMax 3D printer: [www.instructables.com]
November 28, 2017 05:21PM
Does your printer have a Z probe? If so, you can use the probe to set an accurate Z=0 height after homing. Or you can use the Z probe to do Z homing instead of the switch.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
November 29, 2017 04:10AM
Hi Dc42,
Yes, my printer has a Z probe.The way I try to do this now is to put a "caliper" (it´s an old PCB board (1.65 mm thickness) which has a wire attached to it and also connected to the ground of Z-Min connector. The extruder has an alligator clip with a Wire connected to it and to the signal of Z-Min connector. Therefore, when the tip of the nozzle touches the PCB board, a signal is sent to RAMPS informing that Z-Min was reached.
Could you teach me how to calibrate the Z axis using the probe as Z-min?
Thanks,
Marcus
November 29, 2017 02:19PM
If you have RAMPS hardware then I guess you are using either Marlin or Repetier firmware. I am not very familiar with either, so I'll leave to someone else to give you instructions.
Edited 1 time(s). Last edit at 11/29/2017 02:19PM by dc42.
