Problem With Temperatures December 01, 2017 10:04AM |
Re: Problem With Temperatures December 01, 2017 03:47PM |
Re: Problem With Temperatures December 03, 2017 02:48PM |
Re: Problem With Temperatures December 03, 2017 02:51PM |
Re: Problem With Temperatures December 04, 2017 07:29AM |
Re: Problem With Temperatures December 04, 2017 07:55AM |
Re: Problem With Temperatures December 04, 2017 11:18AM |
DjDemonD
The nozzle should look like this for a v6 setup:
[attachment 100189 hotend_wired_4web-1000x1000-2_grande.jpg]
Re: Problem With Temperatures December 04, 2017 11:21AM |
Re: Problem With Temperatures December 04, 2017 02:24PM |
DjDemonD
If the nozzle were screwed all the way into the heater block then it is impossible to tighten it sufficiently to the heatbreak to prevent leaking material and possibly jams, as it would tighten and bind on the heaterblock, and there are no flats on the heatbreak to hold to apply enough torque to tighten the heatbreak onto the nozzle instead of nozzle onto heatbreak (makes me wonder why not but that's another thread)..
Re: Problem With Temperatures December 04, 2017 03:04PM |
Re: Problem With Temperatures December 05, 2017 07:10AM |
Re: Problem With Temperatures December 05, 2017 07:34AM |
Re: Problem With Temperatures December 05, 2017 08:17AM |
DjDemonD
...The only issue with these hotends is the thermal capacity of the heater is lower, so rapid changes from slow details to fast infill can cause the temperature to fluctuate more than with a larger block.
Re: Problem With Temperatures December 05, 2017 09:03AM |
