Mini Mills, Bench Mills. Cutting aluminum extrusions square. December 12, 2017 10:44AM |
Re: Mini Mills, Bench Mills. Cutting aluminum extrusions square. December 12, 2017 12:35PM |
Re: Mini Mills, Bench Mills. Cutting aluminum extrusions square. December 12, 2017 01:03PM |
Re: Mini Mills, Bench Mills. Cutting aluminum extrusions square. December 13, 2017 08:47PM |
Re: Mini Mills, Bench Mills. Cutting aluminum extrusions square. December 16, 2017 07:51AM |
Yeah definitely exagerated the minute-ness in differences in length from the extrusions i received from open builds, they were probably an entire milimeter off on some of the pieces. And they were parts that were intended to run parallel to each other.Quote
691175002
I always recommend taking a look at the g0704 mill because it is so popular. It sits at at price/performance sweet spot, and there is a ton of support for it. The mill you linked will also be fine. I wouldn't go as small as a micromill since you will want to use endmills long enough to clean up 4040 without flipping it over.
The main drawback of machining is that accessories (cutting tools, workholding, metrology) will often cost as much as the mill, and fully equipping yourself from scratch can be even more expensive.
I'm not sure that your expectations are realistic though. Cutting a length of extrusion to 50cm +-0.2mm (for example) is a measuring problem, not a cutting problem. Reliably scribing and then hitting that dimension is not trivial. You could skim it off on the mill, measure the length with calipers, and then trim the excess; but then you need a pair of calipers long enough to measure every piece you cut.
One of the advantages/disadvantages of extrusion is that there are so many degrees of freedom during assembly. Your goal should really be to have everything close enough to look nice, and then tap it all into alignment during assembly. Even if your extrusions are all perfectly sized you will still need to perform alignment during assembly anyways since the brackets and such are not perfectly repeatable.
If you want to build a perfect cube from extrusion you should be looking at surface plates, squares, levels, rubber mallets, calipers, straightedges, indicators, etc... (IMO) On a three axis robot you generally have about five alignments that actually matter, and you should measure and adjust them directly when possible. Everything else is just cosmetic.
Re: Mini Mills, Bench Mills. Cutting aluminum extrusions square. December 16, 2017 07:55AM |
the_digital_dentist
Usually absolute length of frame pieces isn't critical, but matching lengths is - that's how you get square assemblies (that and square milling of the ends). If the mill has a long enough work table, you put a stop on it and use that to mill pieces to matched lengths. I set up stops on a bridgeport mill to finish t-slot pieces and get them to matched lengths easily within 100 um.
Re: Mini Mills, Bench Mills. Cutting aluminum extrusions square. December 16, 2017 10:08AM |
