Another kit, another set of problems. December 18, 2017 01:34PM |
Re: Another kit, another set of problems. December 18, 2017 03:46PM |
Re: Another kit, another set of problems. December 18, 2017 03:49PM |
Re: Another kit, another set of problems. December 18, 2017 06:21PM |
Re: Another kit, another set of problems. December 20, 2017 12:23PM |
Re: Another kit, another set of problems. December 20, 2017 02:15PM |
SupraGuy
Anyway, it'd be nice to get the troubleshooting portion of this over with, so that I can start using the printer.
Re: Another kit, another set of problems. December 20, 2017 02:25PM |
Re: Another kit, another set of problems. December 20, 2017 06:57PM |
SupraGuy
Carefully set the offset as per the instructions that came with the printer. First sign, it seems to wander. The print head itself can't do that, and the probe is solidly mounted, so it should not, but it appears to do so. I can repeat the same process, and sometimes I get about ~1.5mm, and it can be up to 1.9mm. It is not dependent on t e X/Y coordinates, it's the same everywhere.
So given that once moving the Z axis moves at very close (error <1%) to the expected distance, it seems that the error is much larger for small moves. I'd think that this would be an acceleration or jerk setting somewhere, that it's too high, and the motor is missing steps when trying to make small adjustments.
Re: Another kit, another set of problems. December 21, 2017 10:35AM |
Re: Another kit, another set of problems. December 21, 2017 08:05PM |
