Hotend design question December 23, 2017 01:55PM |
Re: Hotend design question December 23, 2017 06:11PM |
Re: Hotend design question December 24, 2017 02:44AM |
Origamib
Is your question in reference to hotends, extruders or both?
Hotend design is limited by size, production method, components (thermistor and heating element) as well as a plethora of other things. The heating block serves a very specific function and its hard to imagine an alternative.
As for material choice, the fact that aluminium dissipates heat is a desirable quality as it also means heat transfers from your heating element quickly. Copper would be the next best material here and I believe e3d now make a copper block.
As far as design goes though, I would love to see a more integrated system that combines extruder, hotend and accessories into one. The titan aero seems close but e3d havn't tackled a part cooling system yet that doesn't require awkward printed brackets. Mounting points in the hotend/extruder for accessories would be a huge bonus.
Re: Hotend design question December 24, 2017 03:10AM |
Admin Registered: 13 years ago Posts: 6,999 |
Re: Hotend design question December 24, 2017 03:20AM |
Re: Hotend design question December 24, 2017 04:19AM |
Re: Hotend design question December 24, 2017 08:09AM |
Re: Hotend design question December 24, 2017 10:20AM |
TheBoy
yea so still the same thing just different name. replace up to the thermal barrier.from the left side with one unit
Re: Hotend design question December 24, 2017 10:33AM |
Re: Hotend design question December 24, 2017 10:50AM |
Re: Hotend design question December 24, 2017 11:01AM |
Re: Hotend design question December 24, 2017 02:35PM |
Trakyan
So basically make a heater block+nozzle in one? Downsides are you can't change nozzles and cleaning or unclogging them becomes much harder. You'd also probably run into a few machining challenges. There could be advantages, care to throw a few into the ring?
Origamib
So you are proposing a hot point, instead of a hot block?
The advantage of having a heating block, is that the relatively large block of aluminium holds the heat well, meaning you can push more filament through before the block loses too much heat and causes extrusion issues. Basically, the bigger the block the more stable your heat output is. A smaller block, or thermal lance, would surely need a higher wattage heat cartridge to keep up, but then you introduce fire hazards. According to E3D, a 100 watt cartridge is enough to melt aluminium.
What are the advantages of a thermal lance that the traditional design does not have?
Re: Hotend design question December 24, 2017 03:42PM |
Re: Hotend design question December 24, 2017 04:52PM |
Re: Hotend design question December 24, 2017 05:00PM |
Re: Hotend design question December 24, 2017 05:20PM |
Re: Hotend design question December 24, 2017 09:39PM |
Re: Hotend design question December 24, 2017 10:04PM |
Re: Hotend design question December 25, 2017 02:56PM |
Re: Hotend design question December 25, 2017 07:50PM |
dc42
The hot ends on my Ormerod printer use combined nozzles/heat breaks made from stainless steel. They have been trouble-free. It still uses an aluminium block to connect the heater cartridge and thermistor to the nozzle.
The hot end made by deltaprintr wraps the heater around the nozzle, see [www.deltaprintr.com]. I haven't tried it, because they don't make a 24V version.
Re: Hotend design question December 26, 2017 01:58AM |
Re: Hotend design question December 26, 2017 04:20AM |
Re: Hotend design question December 26, 2017 03:01PM |
Re: Hotend design question December 28, 2017 04:58PM |
frankvdh
Following from @TheBoy's proposal; imagine putting the nozzle thread inside the heater cartridge. Have a (say) 10mm outside diameter, 6mm inside diameter, 4mm tall tubular heating element with an M6 thread inside for the nozzle (i.e. the nozzle threads extend right through the heater doughnut). Make the heater doughnut out of some material with good thermal mass (metal?) for temperature stability, although fast-responding PID control of the temperature may be good enough? (Not quite sure how to get the nichrome wire and thermistor into it, but maybe someone has some ideas?). Thread the outside of the heater, to screw into a carrier made of a thermal insulator (ceramic or epoxy?), including the top of the tube, leaving a 2mm diameter hole for the filament to enter. All the energy goes into heating the nozzle and the filament inside it, and little escapes from the carrier... no need for a heatbreak, heatsink, or fan.
[attachment 100871 Screenshotfrom2017-12-2608-49-30.png]
[attachment 100872 Screenshotfrom2017-12-2608-52-53.png]
Carrier is grey, heater blue, nozzle yellow, filament red.
Re: Hotend design question December 29, 2017 09:22AM |
Re: Hotend design question January 04, 2018 02:53AM |
Re: Hotend design question January 04, 2018 03:03AM |
Re: Hotend design question January 06, 2018 03:28PM |
TheBoy
Why do we use aluminum to transfer heat to our extruder head? If we wanted a more even heat transference shouldn't it be a metal that doesn't dissipate heat? Why not just put the heating rod in the extruder itself if it's already on a cnc the extra pocket shouldn't matter. It saves a step reduces production time and can still be sold for the same price.
Re: Hotend design question January 06, 2018 04:27PM |
Re: Hotend design question January 06, 2018 04:34PM |
AletheianAlex
TheBoy
Sounds like you are thinking along the lines of an injection-molding style self-heated "hot runner nozzle" concept. You could google that to see what the ins and outs of it are. Even a non-cartridge soldering-iron style helical heater concept may work.
I would not be stoked about an integrated nozzle, but I am on-board with the surround heating element. The mini delta hot ends touch on it, but I hope to grab a bunch of cheap off the shelf examples and run some experiments in the future. If you are interested, search for "band heating element" or "enclosed nozzle heater". Even ceramic helical elements for high-current vape pens may be usable.
A tradeoff -- as was mentioned -- is that you lose the thermal mass of the aluminum block, but spinning a cylinder heat 'block' on a lathe for an insulated surround heater is not unreasonable.
Induction heating is something I also hope to work with in the new year, and that would fall somewhat inline with your brainstorm since you could essentially heat a ferritic nozzle directly rather than indirectly through a thermal mass+cartridge. I worked for a while as a contractor to design and build control equipment to an induction smelting company, so I have a nagging desire to see that concept through with a small breakout board regardless of previous attempts.
