3d printer print first layer okay then z-axis goes to far up.
Posted by Kars007
December 28, 2017 07:54AM
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 94.69 }
I made myself a 3d printer, the printer print the first layer good, but then goes to far up like 1 cm or so.
I use a M8 rod for the printer. Below I have a piece of the program from the printer.
Please help me. Thanks in advance.smiling smiley
#define DEFAULT_MAX_ACCELERATION { 2000, 2000, 100, 10000 }
#define DEFAULT_ACCELERATION 2000 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 2000 // X, Y, Z acceleration for travel (non printing) moves
#define DEFAULT_XJERK 17.0
#define DEFAULT_YJERK 17.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 1.0
Re: 3d printer print first layer okay then z-axis goes to far up.
December 28, 2017 08:35AM
It seems, you don't have microstepping jumpers under the Z-axis driver.
December 28, 2017 08:36AM
I would think that you have the wrong Z-Axis leadscrew numbers.
Take a picture of the Lead screw, and post, Unless you know what the lead is.
The lead is the distance traveled with one rotation.
A T8-8 lead screw will travel 8mm
A T8-4 lead screw will travel 4mm
a T8-2 lead screw will travel 2mm
// Typical stepper motors have 200 steps per full step/rev = 1.8°/step, so 1/16 microstepping = STEPS_PER_REVOLUTION_E = 3200
// X-Y Axis 3200, / 20 tooth, / 2mm pitch = 200*16 / 20 / 2 = 80 :: (STEPS_PER_REVOLUTION_X / IDLER_TEETH_X / BELT_PITCH_X)
// Z Axis 3200, / 1.25mm pitch leadscrew = 200*16 /1.25 = 2560 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 2mm pitch leadscrew = 200*16 /2 = 1600 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 4mm pitch leadscrew = 200*16 /4 = 800 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 8mm pitch leadscrew = 200*16 /8 = 400 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// E-Axia 3200, / (11mm Gear OD * pi) :: (STEPS_PER_REVOLUTION_E * EXTRUDER_GEAR_RATIO / (PINCH_WHEEL_DIAMETER * PI))
Edited 1 time(s). Last edit at 12/28/2017 08:36AM by Roberts_Clif.
December 28, 2017 01:07PM
Thank you for your responds.
It is a T8-8 lead screw. I add a picture of the lead screw just to be sure.
What do I need to change in the software?
Thanks in advance.
open | download - index.jpg (55.7 KB)
December 28, 2017 07:46PM
What kind of controller are you using, If you are using a ramps 1.4 have you installed the jumpers.
December 29, 2017 04:44AM
Yes I have installed the jumpers on the ramp 1.4.
December 29, 2017 03:08PM
What slicer are you using.
Would you post your configuration.h file.
What are you using for stepper motors.
December 29, 2017 06:39PM
I use slice 3 and simplify 3D both does the same thing.
I put the whole program in the attachments. I hope you find the problem.
The stepper motor that I am using is 17HS4401
Thanks in advance, you are the best.smiling smiley
open | download - Marlin.zip (964 bytes)
December 29, 2017 08:14PM
Sorry to say but you only attached Marlin.ino
December 29, 2017 08:37PM
Ooops I am sorry.
I copy and past it in this file.
open | download - config h.txt (66.5 KB)
December 30, 2017 10:55AM
I thought that this was correct
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to same logic as "Z_MIN_ENDSTOP_INVERTING".
[github.com]
Never changed this settings in RC8 and they worked fine. When I upgraded to Marlin 1.1.5 they had to be the same before if work function correctly.
Also required
//A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
#define FIX_MOUNTED_PROBE
Edited 3 time(s). Last edit at 12/30/2017 11:00AM by Roberts_Clif.
January 02, 2018 02:28PM
Thanks it was “// set to same logic as "Z_MIN_ENDSTOP_INVERTING” . It works just fine now thanks a lot.
And happy 2018smileys with beer
