No End stops Prusa i3 Mrk 3 ?
Posted by scubi
January 05, 2018 05:25AM
Hi Guys
Have anyone been able to change their Printer similar to the Prusa i3 MRK3 where the printer does not use end stops for X & Y axis ?
How did you go about doing it ?
Thanks
Vaughan
Re: No End stops Prusa i3 Mrk 3 ?
January 05, 2018 06:57AM
Install tmc2130 stepper drivers with SPI interface
Install latest marlin with tmc2130 driver support and enable it in configuration_adv.h
One of the extra pin on the driver is wired to the endstop pins.
NB it only detects lack of movement in the direction of movement, so good for endstops and some skip detection
See toms guide for ramps... [toms3d.org]
NB if you have a LCD its harder, as you need to get to the SPI pins, which is used by the LCD cables (depending on the controller)
January 05, 2018 09:59AM
scubi
Hi Guys
Thanks
Vaughan
Several users of Duet electronics have done this on various printers. It is supported by the current stable release of RepRapFirmware as standard. I documented the process at [duet3d.com]. To find people using it, go to [www.duet3d.com] and search for "sensorless homing".
