Need Help with bed thickness
Posted by Falcondestroyer123
January 23, 2018 11:12PM
Hey guys i need help which thickness of heated bed. Is 2 mm the standard thickness of a 300x300 mk2a heat bed. Also what is the resistance of a 300x300 24v bed.
Thanks
Re: Need Help with bed thickness
February 20, 2018 01:32AM
My 300x300 mk2a is 2mm and its resistance is 1.6ohms. I am in the process of replacing it with a 6mm MIC6 tool plate with a 24v silicone pad.
February 21, 2018 11:58PM
556duckvader
Same here. I've had enough of the .15mm bow in my glass bed.
February 22, 2018 07:04AM
If you're replacing bed plates with MIC6, you might find this useful. It shows how I converted a glass bed (broken!) on a Taz to MIC6 and mounted it on 3 leveling screws instead of 4.
If you really want to hog-wild, here's the bed design in UMMD, my latest printer. It uses a kinematic mount that allows the bed to expand without creating any bending forces.
I like PEI for the print surface- 30 mils (about 0.7 mm) is enough for it to be almost indestructible.
Son of MegaMax 3D printer: [www.instructables.com]
