AC Heated bed? January 26, 2018 09:04AM |
Re: AC Heated bed? January 26, 2018 09:58AM |
Re: AC Heated bed? January 26, 2018 10:54AM |
Re: AC Heated bed? January 26, 2018 12:57PM |
Re: AC Heated bed? January 26, 2018 01:56PM |
Re: AC Heated bed? January 26, 2018 02:24PM |
gen2eng
This is my first round using AC mains as a heating source and I'm looking for a bit of extra safety and trying to avoid thermal fuses, etc..
Re: AC Heated bed? January 27, 2018 01:42AM |
Re: AC Heated bed? January 27, 2018 03:07AM |
Re: AC Heated bed? January 27, 2018 03:53AM |
Thanks for the clarification as I did misinterpret what I read.Quote
DC42
The Duet firmware doesn't currently support averaging of temperature inputs (although it does support multiple bed heater zones
I agree the TCO is the best route, but was looking for some "some" additional safety at the software level. If I remember correctly, Repetier-Firmware allowed use of a secondary temp input to detect failed and separated thermistors. I've found my Duet 0.85 to be extremely stable having run many small batches of parts and not require periodic resets between prints like the old 8 bit hardware.Quote
the_digital_dentist
Using a TCO in thermal contact with the heater/bed to interrupt power to the heater is the ultimate in runaway protection.
Re: AC Heated bed? January 27, 2018 04:39AM |
sarf2k4
How fast those keenovo AC heaters perform let's say from 30c to 100c?
Then with the AC heaters, we typically could go slightly thinner wires probably 18 or 20awg right?
My main problem with the pcb dc heated bed was that of course, underpowered and often beaten by a fan blowing onto it thus cooling the whole bed down even further. I'm waiting for a cotton insulation sheet to insulate underneath the pcb
Re: AC Heated bed? January 27, 2018 04:43AM |
gen2eng
DC42
the_digital_dentist
Re: AC Heated bed? January 27, 2018 05:29AM |
Re: AC Heated bed? January 27, 2018 05:56AM |
sarf2k4
I guess this is where AC heatbed will start to take over. I've found keenovo's silicone heating pad in aliexpress and considering how much stuff I need to include just for the sake of using ac heatbed can be a bit overwhelming.
How much power in amps does the ac heatbed pulls if it is rated at around 500w and powered using 240v?
sarf2k4
Any temperature drops if for example a big standing fan or the printer's nozzle fan blowing at full speed and how fast will it catch up?
sarf2k4
If I don't rely on the TCO (If I understand it right it is Temp Cut Out module?) to cut off the overtemp but to use the marlin's thermal runaway protection, would that suffice?
sarf2k4
I understand grounding is very important, I saw maker's muse got shocked due to improper grounding in his whole circuit, can I connect a wire from a printer's frame to the dc psu's ground terminal directly?
sarf2k4
I wanted to reduce power outlet usage, can I wire the ac heatbed into the psu's ac input terminal then to the relay?
sarf2k4
Any other alternative than using bulky SSR?
Re: AC Heated bed? January 27, 2018 07:01AM |
sarf2k4
Re: AC Heated bed? January 27, 2018 09:17AM |
Re: AC Heated bed? January 28, 2018 02:54AM |
Re: AC Heated bed? January 28, 2018 03:05AM |
Re: AC Heated bed? January 28, 2018 03:52AM |
Re: AC Heated bed? January 28, 2018 09:34AM |
Re: AC Heated bed? January 28, 2018 10:29AM |
the_digital_dentist
... I would not connect the power supply negative output to the printer's frame with the line input ground. The voltage reference in the supply comes from the output side of the supply and if you tie it to the power line ground you're liable to be adding power line noise to the DC ground. But if you search the web for engineering documentation from switching power supply makers, it isn't hard to find justification for either connecting it or not.
Re: AC Heated bed? January 29, 2018 01:00AM |
the_digital_dentist
Do connect the power supply input ground to the line input ground/neutral. I would not connect the power supply negative output to the printer's frame with the line input ground. The voltage reference in the supply comes from the output side of the supply and if you tie it to the power line ground you're liable to be adding power line noise to the DC ground. But if you search the web for engineering documentation from switching power supply makers, it isn't hard to find justification for either connecting it or not. In the end, you probably have to evaluate it on a case by case basis. If you get weird behavior with the output of the DC supply grounded, open the DC ground connection, and the reverse. In a home environment with a relatively quiet power lines, it may not make any difference. In terms of safety, grounding the output to the printer's frame means you've got one side of the DC power supply everywhere and it is pretty easy to accidentally create a short. If you leave the supply floating, you don't have that easy accidental connection to DC ground.
Re: AC Heated bed? January 29, 2018 07:40AM |
Re: AC Heated bed? February 06, 2018 02:50AM |
Re: AC Heated bed? February 06, 2018 09:00AM |
Re: AC Heated bed? February 08, 2018 02:27AM |
Re: AC Heated bed? February 08, 2018 07:36AM |
