Original Full Color Hotend Mount CAD-File?
January 29, 2018 05:01PM
Hello
I need to edit this file: Link
But editing STL files is hard and i wanted to ask you if someone has the original cad file?
Re: Original Full Color Hotend Mount CAD-File?
February 01, 2018 01:16PM
The STEP file in the thing files seems to be correctly formatted and quite usable. What CAD program are you using?
Mike
February 02, 2018 05:47AM
I like to use sketchup or fusion360. But importing STL makes thousands of little triangle areas
February 02, 2018 06:39AM
In the Thing files of the link you gave there is a file called Diamond_Hotend_Fullcolor.stp (NOTE: this is not .stl)
You should be able import this as solids instead of surfaces in Fusion360 and there is and extension for Sketchup called the SimLab STEP importer that should also work. STL won't work without major effort because STL files are all surfaces.
Mike
February 02, 2018 10:42PM
The provided STP-File is only the Hotend itself. NOT the mount. That's only available in STL.
Meine Drucker:
BQ-Hephestos 2 (heavy moded):
Arduino/Ramps1.4(12V) mit TMC2100 Stepper Drivers (stealthchop mode), BLTouch ABL Sensor, ohne LCD, TR8x1.5 Z-Axis Trapezgewinde, selbst entwickelte Rahmenverstärkung des Hauptrahmen.
Octoprint@Pi und Simplify3D
FatMax3D (eigendesign/-bau):
70x50 Aluminiumprofile, Arduino/Ramps1.4(24V) mit TMC2208 Stepper Driver (stealthchop2 mode), JUGETEK N17 0.9° Schrittmotoren, BQ Inductive ABL Sensor(BLTouch kommt bald), 12864 LCD Controller,
E3D6Lite Hotend mit Volcano Upgrade(bis 1.2mm Düse), BONDTECH QR DualDriveGear Extruder, Druckvolumen von 500x400x700 (Momentan auf eine Startgrösse von 300x200x700 wegen des kleinen Bettes limitiert)
February 03, 2018 05:44AM
