ABS Supplier in the US
Posted by brnrd
April 14, 2011 08:53PM
Ultimachine seems to be completely out of ABS. Not much selection in Makerbot either. Are there other sources for 3 mm ABS?
Thanks.
Re: ABS Supplier in the US
April 15, 2011 10:29AM
Here are two suppliers in the US.
[plasticweldingrod.com]
[www.villageplastics.com]
smiling smiley
April 15, 2011 11:58PM
Makerbot store has a good supply of ABS in 3mm and 1.75 mm. I've had nothing but good experience with them. If there is enough interest, I have some imported and sell on my blog.
April 16, 2011 07:50PM
@Cdnreprap - Thanks. Does villageplastics sell ABS? It wasn't listed as one of the choices for a quote.
@13thfloor - Makerbot seems to be low on supply.
I'm looking for natural color ABS.
April 16, 2011 08:24PM
What are the popular colors and diameters that people need. I see that natural is a choice. I'll see if I can contact some Chinese manufacturers for a shipment. Last time I checked, they want 20kg/color minimal.
April 16, 2011 08:56PM
I read in the makerbot operators group that village plastics is the supplier for Makerbot so they probably sell ABS. I requested a quote. I'll see what their response is. There's also another supplier that I found there: [www.abbeon.com]. They sell natural ABS for $57 for a 5 lb coil. Ultimaker's price is lower at $45 but they're out of stock.
April 18, 2011 06:53AM
@13'thfloor
Be sure to manage the quality when talking to the Chinese. Someone in the UK got a load of stuff but unfortunately the quality was a little off - the profile was oval at probably 3.2 by 2.8 or thereabouts. Nasty profile.
April 19, 2011 02:17AM
Makergear has some 3mm ABS in stock:
MakerGear.com - Filament
April 19, 2011 08:52AM
> smiling smiley
I received a reply from them. Both of them have 3 mm ABS in stock for around $40 and $50 per 5 pound coil, respectively in their stock colors.
April 19, 2011 10:04PM
AgeingHippy Wrote:
> @13'thfloor
Also request material data sheets. 'ABS' has an incredibly wide range of properties, depending on just which resin you're using. Makerbot uses PA-747, Stratasys uses injection mold resins (MG94 and such).
[haveblue.org]
April 20, 2011 02:05PM
Is MG resin consider the best? What's the main difference between that and abs 747 and 747 in terms of printability?
May 05, 2011 02:57PM
MG47 prints much better on a Stratasys machine than PA-747 does. The biggest difference between the two is that the MG47 has a much higher melt flow rate (you can push the material through a nozzle much more easily at a given temperature).
[haveblue.org]
May 05, 2011 03:11PM
I talked to a manufacturer, and was told that 746 would be easier to extrude than 747 as well.
May 06, 2011 11:20AM
The 756 series will be even easier than the 746.
[haveblue.org]
May 06, 2011 06:58PM
Ultimachine is begining to get ABS and PLA back in stock. They have Black ABS only at the moment, and Green, Blue, Black and White PLA.
