jesse002100
I've leveled it several times thru the menu and it does a 9 point leveling before each print.
photos.app.goo.gl]
You can save bed leveling data using M500 or menu "Store settings". And by adding "M420 S1" to end of start G-Code. Other Unified bed leveling functions do not work with linear or Bi-linear bed leveling.
G92 E0 ;reset extruder length (last line of my G-Code)
M420 S1 ; Bed Leveling On
Be sure to remove the Auto Bed Leveling Command from Startup G-Code
jesse002100
Second issue is the screen goes to gibberish and will come back if I hit the center button but it has seemingly caused the printer to stop and reset or it was a coincidence.
photos.app.goo.gl]
Not sure why but my controller hates the LCD wires being close to each other. I ended up using aluminum foil Duct Tape, and taped each ribbon cable to opposite sides of the t-Slot.
jesse002100
And lastly the center of the slicer does not print on the center of the bed its off a good but on x/Y.
photos.app.goo.gl]
Have never got my 3D Printer to Home dead center bed but it is close. I think it is because the X, Y offset for Z-Axis Proximity sensor location, changes the home position calculation.
