TMC2130 Stallguard
Posted by S1CAR1US
TMC2130 Stallguard
February 06, 2018 06:03PM
Hi all, I have just installed some tmc 2130s and not having much luck. Can someone who has experience give me some feedback on this log file maybe? Right now I am getting no movement but I was originally out of only one axsis. I followed the Toms guide...
14:55:17.337 : N79 M122*28
14:55:17.379 : X	Y
14:55:17.379 : Enabled		false	true
14:55:17.379 : Set current	0	0
14:55:17.379 : RMS current	1767	979
14:55:17.379 : MAX current	2491	1380
14:55:17.379 : Run current	31/31	31/31
14:55:17.379 : Hold current	12/31	12/31
14:55:17.379 : CS actual		0/31	31/31
14:55:17.379 : PWM scale	0	255
14:55:17.379 : vsense		0=.325	1=.18
14:55:17.379 : stealthChop	true	true
14:55:17.379 : msteps		256	0
14:55:17.379 : tstep		1048575	4294967295
14:55:17.379 : pwm
14:55:17.379 : threshold		0	0
14:55:17.379 : [mm/s]		-	-
14:55:17.379 : OT prewarn	false	true
14:55:17.379 : OT prewarn has
14:55:17.379 : been triggered	false	false
14:55:17.379 : off time		0	15
14:55:17.379 : blank time	16	54
14:55:17.379 : hysterisis
14:55:17.379 : -end		-3	12
14:55:17.379 : -start		1	8
14:55:17.379 : Stallguard thrs	50	0
14:55:17.379 : DRVSTATUS	X	Y
14:55:17.379 : stallguard			X
14:55:17.379 : sg_result		0	1023
14:55:17.379 : fsactive			X
14:55:17.379 : stst		X	X
14:55:17.379 : olb			X
14:55:17.379 : ola			X
14:55:17.379 : s2gb			X
14:55:17.379 : s2ga			X
14:55:17.379 : otpw			X
14:55:17.379 : ot			X
14:55:17.379 : Driver registers:
14:55:17.379 : X = 0x80:00:00:00
14:55:17.379 : Y = 0xFF:FF:FF:FF
14:56:03.993 : N80 G91*41
14:56:03.993 : N81 G1 Y1 F4800*51
14:56:03.993 : N82 G90*42
Also, since installing, I am getting what appears to me to be noise on my thermistor readings...
Edited 1 time(s). Last edit at 02/06/2018 06:13PM by S1CAR1US.
Re: TMC2130 Stallguard
February 08, 2018 12:02AM
have you looked here [github.com] and arduino library [github.com] another site [hackaday.com] what the first link is the marlin setup the second is an arduino library file and info and the third site is detailed discussion of the driver. This driver is a very complex unit with many variables to setup and at some point recommend a scope to setup. It appears you only have y axis enabled. I have not used this driver but am interested to know more about it. Do you have the SPI hooked up.
