Auto Bed Leveling issue
Posted by tmccar
February 13, 2018 01:48PM
I've just built a Tevo printer. It has an auto-levelling probe and I set up the firmware with "FIX_MOUNTED_PROBE" as the probe type. When I clicked on "Z home" on Repetier Host. it went up in Z and would probably have gone through the topof the printer if something had not been in the way. So then I looked at my configuration and changed "#define Z_HOME_DIR -1" to plus 1.
But when I upload, I get this error:
#error "Enable USE_ZMAX_PLUG when homing Z to MAX."
Re: Auto Bed Leveling issue
February 13, 2018 03:01PM
If you want the Z to home to where the nozzle is close to the bed, then you had it correct the other way, with Z_HOME_DIR set to -1. This is USUALLY the way that these printers home.
If you want it to home as far away from the bed as it gets, then you need to have a limit switch attached at that point.
More likely what you want to do is find the
#define INVERT_Z_DIR false
line in your configuration.h and change it, so that the motor turns in the direction that you need in order to move in the expected direction.
MBot3D Printer
Kit from Amazon
Added heated bed.
I3 beltless redesign (in progress)
Duet Wifi, Precision Piezo parts
February 14, 2018 08:27AM
Ok, thank you
