Designing a Reprap for printing digital sculptures
Posted by ilion
April 18, 2011 09:19AM
So I'm new to the reprap project, and I was looking to build a system specifically for printing digital sculptures that I have modeled in a 3D package such as Maya or 3DS Max.
This would obvioulsy need to have as little "artifacting" (imperfections) as possible in the end product and print those details very well, as well as have a smooth finish. (by smooth finish, I just mean consistant, without Striation. It doesn't need to feel like it's glass or anything, although, smoother the better)
So here lies the questions.
Is this possible (at a relatively similar cost to currently marketed Prusa machines)?
Which plastic would be best for this?
What size filament would be best?
Any ideas for a 3d printer specifically for this purpose?
Any systems that are currently being built that could handle tasks like this?
I appreciate the feedback and input!
Re: Designing a Reprap for printing digital sculptures
April 18, 2011 09:33AM
ilion
Sounds like the finish you are looking for is currently not achievable with the reprap printers.
Perhaps you can look at this although I don't know if he has released any build plans anywhere yet.
April 18, 2011 07:34PM
That's great! Thanks for the link.
April 18, 2011 11:54PM
The look is certainly achievable with reprap although it would require some dipping in say conformal coating. The technique that guy uses is also adaptable to reprap.
I think he uses a projector to cure the liquid, right? With a reprap, you would simply need to dip some kind of curing wand into the bottom of the fluidfilled container and print as you would with filament, only you would not see the results until you drain the remaining liquid out b
VDX
April 19, 2011 03:25AM
... with a projector you cure a complete slice in some seconds, then process the next ... with an UV-diodelaser as RepRap-toolhead you can do the same, but then you have to process the slice pixelwize, so you'll need much more time - i'll estimate some ten minutes per slice for the same accuracy as with the projector!
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
May 19, 2011 04:34PM
A bit with the same idea than ilion
Really new here, basically I would like to print that kind of things "printing digital sculptures that I have modeled in a 3D package such as Maya or 3DS Max". and was wondering if printers like Ultimachine or Orca would work for this.
I believe I won't get what expensive laser printer do but was wondering if buying one of these could do the job....
or if someone can help on finding the best quality in terms of details and precision...
thanks !
May 19, 2011 05:03PM
I think one of the best processes for digital sculpture is a powderbed, but I may be biased.
Random Precision
May 20, 2011 10:27AM
thanks. I didn't know these
Anybody here use reprap to print little sculptures ? or that kind of stuff ?
May 20, 2011 03:59PM
Just look at www.thingiverse.com there are loads of 'little sculptures' being shared and printed there every day. And a whole load of other useful, and not so useful, things!
May 20, 2011 05:55PM
Getting back to the topic, there is a way to obtain really glassy smooth finshes on some printed objects. With PLA at least, you can blow it on the low setting with a hot air gun, and the surface will flatten as surface tension forces pull the plastic in. I've done it two different ways. With the heat gun, you get some control, but distrubution of heat can be uneven, and warp things slightly. I also tried in an oven, but somehow, the melting was more rapid and penetrating, so the part really started to lose structure in a major way. In the end though, the finish was like glass.
May 20, 2011 07:25PM
Supposedly an acetone vapor bath can smooth out abs.
[blog.erikdebruijn.nl]
May 21, 2011 06:50AM
If you are talking sculptures, why not use a car body filler, that works with PLA
and I guess it is used on cars to get a glossy finish of the varnish of the car..
I guess with some experimentation it could give a good base for a colour at least!
Smooth and glittery..
Cheapest PLA on the net Supply3DPLA.com
May 24, 2011 03:53PM
Ironically, I actually started a topic quite soon after this looking for artists using RepRap as I'm researching some articles for the International Sculpture Center website on the subject of RP sculpture and specifically artists using this sort of tech. Not found many yet, but if any do reveal themselves I'll let you know what setup they're using.
Conversely, have you got any renderings of the sort of things you're looking to print?
Kind regards,
John
May 25, 2011 05:01AM
was just wondering if right now a reprap machine would be able to print something like an alien head like the Giger version for example in a good quality ???
lot of things on www.thingiverse.com for sure but I believe there might be a lot of better printed things out there and not the usual downloadable stuff...
May 25, 2011 11:15AM
If you're just looking for 3d models there are 100s of websites. Here's a link to a few:
[www.hongkiat.com]
However, most are built for 3d applications like 3dMax. So you'll have to convert them to a format that can be printed, and take into consideration how overhangs in the model will be supported, simplifying detail etc.
June 10, 2011 07:13AM
> abs.
> [blog.erikdebruijn.nl]-
> am,-yes....html
Perfect! This is something I am looking to utilize. Thanks for the link, and I will be researching this a bit while I try to figure out whether I want to attempt this with a Reprap or wait for some other DIY technology to surface (such as the projector listed in the link form ageinghippy)
June 10, 2011 10:45PM
If you want to produce art (no need for strength) I suggest looking into ACTUAL 3d printers. They bind together powder with ink. This approach has several artsie advantages like support for overhangs, smooth surface finish, and a full range of colors.
[www.makerbot.com]
[www.architecture.yale.edu]
[en.wikipedia.org]
June 13, 2011 11:55PM
I think I may have solved your surface finish problems. See this post
[forums.reprap.org]
