What Do People Want In A CNC? February 26, 2018 04:28PM |
Re: What Do People Want In A CNC? February 26, 2018 05:43PM |
Re: What Do People Want In A CNC? February 26, 2018 06:26PM |
Re: What Do People Want In A CNC? February 26, 2018 08:41PM |
Re: What Do People Want In A CNC? February 26, 2018 08:55PM |
Admin Registered: 15 years ago Posts: 7,337 |
Re: What Do People Want In A CNC? February 26, 2018 11:16PM |
Re: What Do People Want In A CNC? February 26, 2018 11:35PM |
Re: What Do People Want In A CNC? February 27, 2018 01:04AM |
Re: What Do People Want In A CNC? February 27, 2018 01:57AM |
Re: What Do People Want In A CNC? February 27, 2018 03:45AM |
Re: What Do People Want In A CNC? February 27, 2018 05:01AM |
Re: What Do People Want In A CNC? February 27, 2018 05:18AM |
computer driven routers?? aint that a box that connects a series of computers together with a connection to the web?Quote
MKSA
First, please don't call that a CNC, there are just computer driven routers
Re: What Do People Want In A CNC? February 27, 2018 05:47AM |
Admin Registered: 18 years ago Posts: 14,176 |
Re: What Do People Want In A CNC? February 27, 2018 05:55AM |
Re: What Do People Want In A CNC? February 27, 2018 05:59AM |
Re: What Do People Want In A CNC? February 27, 2018 06:29AM |
from what I've been reading your budget low for the size of machine you planning even with ali offering, its gonna get eaten on a good set of ball screws, nema 23 and a spindle " hope am wrong and good luck with the build"Quote
Trakyan
Currently looking at around $250 USD for a machine with around 1mx1m cutting area
Re: What Do People Want In A CNC? February 27, 2018 07:18AM |
Trakyan
MKSA needs to look up what C(Computer)N(Numerical)C(Control) stands for. I'll admit I used the term incorrectly in my OP, but really it just means a machine which can move a tool head that is controlled via a computer, it says nothing of what that toolhead is. It could be a wood router, extruder or laser for all anyone cares. It's just there is an unspoken consensus that CNC is synonymous with a CNC Mill.
Besides, the machine I'm planning to build is going to be build on a budget. Currently looking at around $250 USD for a machine with around 1mx1m cutting area, and that's with a "fancy" controller board. Why so cheap? Because, looking at my wallet, the $1000 machine I had planned was well out of my price range :-). That machine in the video looks spectacular, but it's completely useless to me since I can't afford it and am no closer to having a machined part than if I asked the work piece really nicely to get itself in shape for me.
After all, the best tool for the job is the one you can afford.
) it is misleading.
Re: What Do People Want In A CNC? February 27, 2018 09:38AM |
jinx
VDX you got a build blog for them, like the small one on the right, " got a vid of it in action". while researching I realised I should have gone with a static bed rather than moving the job back and forth but used what I had in the scrap box!
Re: What Do People Want In A CNC? February 27, 2018 10:10AM |
Trakyan
3d Printers really spiked in popularity after machine costs fell into the several hundreds, not several thousands, even if quality wasn't completely spectacular at the time. I'm looking to do something similar for CNC.
Re: What Do People Want In A CNC? February 27, 2018 10:43AM |
Re: What Do People Want In A CNC? February 27, 2018 02:28PM |
Re: What Do People Want In A CNC? February 27, 2018 02:43PM |
recall the same thing seeing a review with broken parts.Quote
Trakyan
From what I know, those are plastic plates, not aluminium. I saw a couple of video reviews and people said it's plastic, plus it cracked like plastic.
Re: What Do People Want In A CNC? February 27, 2018 03:02PM |
Re: What Do People Want In A CNC? February 27, 2018 05:05PM |
jinx
VDX that is some inspiring work there in the vids the Movtex-xy vid "thought that was quite ingenious method of travel on the Y axis would that hold up for a spindle?
Re: What Do People Want In A CNC? February 28, 2018 01:06AM |
Re: What Do People Want In A CNC? February 28, 2018 02:45AM |
Trakyan
I don't plan to use ballscrews, I'm thinking belts should be fine as long as I keep feed rates realistic.
@MKSA, A tool that can do a job is no good to me if I can't afford it. It might as well be a fairly tail. And even second hand machines of the type you're talking about are way out of most people's price range. Where I live, these sorts of tools aren't common to begin with so second hand ones are even less common.
For the record, I'm not saying the machine I'm building will revolutionize anything, or be a substitute or expensive machines. All I'm saying is that it will provide an affordable entry point. We'll see how successful I am, but for now I'm aiming for a rock bottom cost machine that does the job. It won't be as fast or as accurate, but with any luck it will work.
Re: What Do People Want In A CNC? February 28, 2018 03:19AM |
Re: What Do People Want In A CNC? February 28, 2018 05:56PM |
I'd quickly get ripped apart for using steel tubing from the hardware store as a linear guide. I'm going to build it anyway, I want/need a CNC and this is what I can afford. My initial plans were for a CNC built out of 2080 aluminium extrusions and steel plate. This was going to cost me around $1000 USD. For someone in my situation, I can't justify spending that much on a single machine even if I had the money.
Re: What Do People Want In A CNC? February 28, 2018 08:27PM |
Re: What Do People Want In A CNC? February 28, 2018 11:57PM |
