just got my motors and electronics working , figured id test while waiting to the extruder to get here. but i ran into a problem , and am not sure what to do.
Since im on Gen6 i use repsnapper to send gcode , but i convert the 3d model into gcode using skeinforge. when i load the gcode it shows like this.
also if i were to load the stl into repsnapper it is on the other side of the buildplate/gcode like this. This would be the correct way to print , but repsanpper doesnt convert gcode properly so i cant use it.
and this is what my print is like (it started going off the page plus i darkened some spots so you could see, also the N was too low and the belt skipped, so only problem is it being flipped and mirrored)
if i look at it from the other side(holding up to light) then the image is right.
so is skeinforge converting the gcode wrong , or would it be something in my settings , or is it repsnappers fault ? also it does this for every stl , ive tried multiple(even some off thingiverse).
Edited 3 time(s). Last edit at 04/21/2011 11:47PM by Rooski.
