Z axis problem on a Bottom up 3D Printer April 02, 2018 07:35AM |
// @section homing // Specify here all the endstop connectors that are connected to any endstop or probe. // Almost all printers will be using one per axis. Probes will use one or more of the // extra connectors. Leave undefined any used for non-endstop and non-probe purposes. #define USE_XMIN_PLUG #define USE_YMIN_PLUG //#define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG #define USE_ZMAX_PLUG // Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way. #define INVERT_X_DIR true #define INVERT_Y_DIR true #define INVERT_Z_DIR false // Direction of endstops when homing; 1=MAX, -1=MIN // :[-1,1] #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR 1 // @section machine // The size of the print bed #define X_BED_SIZE 310 #define Y_BED_SIZE 215 // Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS X_BED_SIZE #define Y_MAX_POS Y_BED_SIZE #define Z_MAX_POS 200
Re: Z axis problem on a Bottom up 3D Printer April 02, 2018 08:00AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: Z axis problem on a Bottom up 3D Printer April 02, 2018 08:47AM |
Re: Z axis problem on a Bottom up 3D Printer April 17, 2018 08:57PM |
Re: Z axis problem on a Bottom up 3D Printer April 18, 2018 02:51AM |
Re: Z axis problem on a Bottom up 3D Printer April 18, 2018 06:45AM |
// @section homing // Specify here all the endstop connectors that are connected to any endstop or probe. // Almost all printers will be using one per axis. Probes will use one or more of the // extra connectors. Leave undefined any used for non-endstop and non-probe purposes. #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG //#define USE_ZMAX_PLUG
Re: Z axis problem on a Bottom up 3D Printer April 18, 2018 07:51AM |
Re: Z axis problem on a Bottom up 3D Printer April 18, 2018 08:08AM |
Re: Z axis problem on a Bottom up 3D Printer April 18, 2018 08:57AM |
Re: Z axis problem on a Bottom up 3D Printer April 18, 2018 10:06AM |
Re: Z axis problem on a Bottom up 3D Printer April 18, 2018 10:30AM |
