Thoughts on a beginner CNC April 12, 2018 01:55AM |
Re: Thoughts on a beginner CNC April 12, 2018 03:22PM |
Re: Thoughts on a beginner CNC April 12, 2018 05:37PM |
Re: Thoughts on a beginner CNC April 12, 2018 06:12PM |
Re: Thoughts on a beginner CNC April 13, 2018 01:05AM |
Re: Thoughts on a beginner CNC April 13, 2018 01:17AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: Thoughts on a beginner CNC April 13, 2018 01:49AM |
Re: Thoughts on a beginner CNC April 13, 2018 03:54AM |
Re: Thoughts on a beginner CNC April 13, 2018 04:30AM |
Trakyan
Anyone got any more opinions on the price point such as machine would need to hit? Also any thoughts on the work envelope? I'm personally leaning in favor of a large format machine because I have 1-2 projects that would use the size, but other than that I think the majority of my work would fit into a 300x300 mm work area quite comfortably.
Re: Thoughts on a beginner CNC April 13, 2018 05:02AM |
Re: Thoughts on a beginner CNC April 13, 2018 05:08AM |
Re: Thoughts on a beginner CNC April 13, 2018 07:32PM |
I got ya. my point was simply make it heavy if possible. heavy can still be cheap. The end result is you get outside the resonance. The drawback to heavy is the mass has to accel/decel but thats only a problem on a 3d printerQuote
Trakyan
Thanks for the responses guys.
@Bill Clark, I fully understand where you're coming from, but a cast iron, 8000 lb machine isn't really affordable or desktop (at least for most people), and that's what I'm going for. I'm talking more about routers than mills, things like the X-Carve, Shapeoko, R3, MPCNC and the like which can machine woods, plastics and aluminium (slowly). Making a cheap milling machine isn't realistic from my point of view, which is why I'm calling it a router. There is nothing I can do to make a "proper" router with rails, heavy duty gantry and so on that someone else can't do cheaper. So what I'm trying to do is taking an approach similar to the MPCNC and R3, trying to build something different that is inherently cheaper.
Re: Thoughts on a beginner CNC April 14, 2018 02:41AM |
Re: Thoughts on a beginner CNC April 14, 2018 08:56AM |
Re: Thoughts on a beginner CNC April 14, 2018 11:55AM |
Re: Thoughts on a beginner CNC April 15, 2018 09:45AM |
Do you mean using either as a linear slide/guide?Quote
Trakyan
. Do you think either round or square tubing is a better choice as a "rail". I know neither is intended for this use, but like I said I'm building to a price point. Have you found either to be more or less straight or in spec than the other?
Re: Thoughts on a beginner CNC April 15, 2018 07:38PM |
Re: Thoughts on a beginner CNC April 15, 2018 08:39PM |
Re: Thoughts on a beginner CNC April 15, 2018 11:27PM |
Re: Thoughts on a beginner CNC April 16, 2018 02:34PM |
Re: Thoughts on a beginner CNC April 17, 2018 02:57AM |
Re: Thoughts on a beginner CNC April 17, 2018 01:54PM |
Re: Thoughts on a beginner CNC April 17, 2018 07:47PM |
Re: Thoughts on a beginner CNC April 18, 2018 02:57AM |
Re: Thoughts on a beginner CNC April 18, 2018 05:21AM |
o_lampe
You don't have to use the pipe as_is.
I know it's a lot of work, but could you treat the pipe surface to become smoother? Sanding it down, while it spins...
But be careful with zinc-plated iron pipe, don't inhale the dust.
Re: Thoughts on a beginner CNC April 18, 2018 01:54PM |
Re: Thoughts on a beginner CNC April 18, 2018 03:15PM |
Re: Thoughts on a beginner CNC April 18, 2018 05:43PM |
Re: Thoughts on a beginner CNC April 18, 2018 05:56PM |
Re: Thoughts on a beginner CNC April 19, 2018 03:03AM |
Trakyan
So you're prefer a lathe over a mill?...
