Only 1.75mm, cheap stuff you find on Ali or Banggood. There are two models basically, one you can adjust T° and it displays it, a cheaper one where you adjust the T° with a trimpot. I got the cheapest and it is OK even for ABS (It stinks the same as from a printer).
I use it as a hot glue gun, to fix, fill, repair. Does a good job.
Don't expect to be able to "draw in the air" and make useful things out of it though; unless you can interpret Gcode and move your hand accordingly
Edited 1 time(s). Last edit at 04/18/2018 02:55AM by MKSA.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
