Inductive sensor question April 25, 2018 05:18PM |
Re: Inductive sensor question April 25, 2018 06:03PM |
Re: Inductive sensor question April 26, 2018 01:48AM |
Re: Inductive sensor question April 26, 2018 07:09AM |
o_lampe
I have 8mm and 12mm diameter sensors. To improve senitivity of the 8mm sensor, I wrapped a strip of thick aluminum foil around the lower part and then adjusted the foils height until the sensor just doesn't trigger anymore. That added another 1mm to the trigger height. (YMMV). Depending on the thickness of the aluminum bed, it might work out for you. But 3mm glass is a tough task.
The 12mm sensor is the safest way to go, but bulky/heavy.
Re: Inductive sensor question April 26, 2018 09:58AM |
