Re: Stackable, printed extrusions that can be filled with resin April 28, 2018 03:19AM |
Re: Stackable, printed extrusions that can be filled with resin April 28, 2018 05:31AM |
Re: Stackable, printed extrusions that can be filled with resin April 28, 2018 12:45PM |
Re: Stackable, printed extrusions that can be filled with resin April 28, 2018 03:27PM |
Re: Stackable, printed extrusions that can be filled with resin April 29, 2018 01:58AM |
Re: Stackable, printed extrusions that can be filled with resin April 29, 2018 02:00AM |
o_lampe
Why did you choose 50mm height? Is that your printers max. height? I think, making them as long as possible will reduce the number of contact areas ( read: chances of misalignment )
Re: Stackable, printed extrusions that can be filled with resin April 29, 2018 02:05AM |
klcjr89
This hasn't been an issue at all. Ready to go straight off a well-tuned delta printer.Quote
o_lampe
You'd have to cut the ends very precise, before stacking them.
It was done to keep possible print failures at a lower point instead of printing a 300mm tall extrusion and have it fail and waste plastic.
Re: Stackable, printed extrusions that can be filled with resin April 29, 2018 08:19AM |
klcjr89
o_lampe
Re: Stackable, printed extrusions that can be filled with resin April 29, 2018 09:47AM |
Origamib
klcjr89
o_lampe
I'f you're worried about adhesion... get creative. Add some ribs to the design that are a single extrusion thick (0.48mm in my case) and then cut them off with a sharp blade. Add a brim for extra strength.
