Anonymous User
ULTIMAKER: Belts, Timing Pulleys & Bushing
April 26, 2011 11:06PM
Does anybody know where I could order some of the Ultimaker parts from? I'm looking for:
Timing belt from the Nema 17 to the shaft (X&Y)
Open ended timing belt (600mm +)
Timing pulley they use for the motor
Timing pulley they use for the 8mm shaft
Bushing for all the bars.
Any help is better than no help :-) Extra question, does moving to T2.5 instead of T5 increase resolution in the print?
Cheers,
Mark
Re: ULTIMAKER: Belts, Timing Pulleys & Bushing
April 26, 2011 11:24PM
T2.5 wont increase resolution unless you have a smaller pitch diameter on the pulley. You wont be printing T2.5 rez pullies, so the manufactured pullies may result in higher accuracy than T5 printed pullies, but there are a number of other factors that affect your accuracy. You know the diff between resolution and accuracy right?
April 26, 2011 11:55PM
sdp-si has all the pulleys you need, though you may need to drill and tap a set screw into certain pulleys. It looks like the ultimaker uses mxl sized belts and pulleys.
I couldn't find a good source for stock brass/graphite bushings, but using an O (as in Orange) drill bit makes a perfect slip fit on 8mm shaft, so you can make your bushings out of whatever you want. Plastic works almost as well as brass for this, as there is very little dynamic loading. If you go this route, be warned the bushings will bind occasionally until the belts are attached, so don't be too worried in testing before the belts are on.
April 27, 2011 04:57PM
McMaster has all the belts you could want, assuming you are in the US, of course.
Would be nice if the country of origin showed up next to our names, huh?
October 03, 2011 05:03PM
I'm on SDP/SI's web page right now. I can't find MXL pulleys for 8mm shafts (0.313") except for polycarbonate ones with 36 teeth that are almost an inch wide.
October 03, 2011 07:50PM
The only ones they have don't have a hub.
[sdp-si.com]
October 04, 2011 12:14AM
I also recommend Misumi.
[us.misumi-ec.com]
October 04, 2011 01:13PM
I went from printed T5 pulleys to metal GT2 pulleys (2mm pitch) from SDP/SI. I was able to find a GT2 pulley with a Ø5mm bore that had a smaller pitch diameter than the printed 8-tooth T5. As a result, I need more steps/mm which worked out to something like a 20% increase in resolution (and acceleration). The machined pulleys are also much more precise than the printed ones, so my prints are looking hugely better.
October 04, 2011 01:32PM
Where did you get them?
October 05, 2011 08:49AM
These, from SDP/SI.
October 05, 2011 02:16PM
Is it possible for me to RepRap my own collar to take a set screw, and epoxy that to the side of a polycarbonate timing pulley?
The part I have in mind (A 6M16M020DF60 at SDP/SI) is this one:
[sdp-si.com]
How about epoxying one of those to the side of a brass sleeve, which I drill and tap for set screws? I am also open to other suggestions.
October 05, 2011 03:10PM
I drilled and tapped a very low profile 8-32 set screw right through the teeth of the pulley, so it did not interfere with the belt mesh. Not the ideal situation, but it did work.
October 05, 2011 03:46PM
Wow. That's *very* low profile. How much thread do you have in there, like 2mm? A colleague has suggested that I get 6mm bore aluminum timing screws and that he could use the edge detectors on the CNC router to automatically find the exact center of the piece and rebore the holes to 8mm. I'm not entirely convinced yet, though.
I suppose I could also have the laser cut holes made larger, get larger bearings, and just epoxy the pulleys in place with the bushings already in between. If the bearing holes are large enough to pass the pulleys through, then we should be fine.
October 05, 2011 04:01PM
I sanded down the set screws until they had a hole through the middle of then tongue sticking out smiley
The pulley material takes to the tapping surprisingly well and never stripped on me.
Did you contact the ultimaker guys and see if they would sell you just the pulleys?
October 05, 2011 05:03PM
Should I be getting pulleys for 6mm belts, or 9.5mm?
Hi, I would like to know if the Ultimaker uses 1,75mm or 3mm filament, or if it could use both. Also, I would like to know if the material thickness would have any impact on the parts detail. Could you get smaller and more detailes parts using 1,75 plastic?
I would use the machine to make prototypes of injection molded parts, so I need at least 0,015mm max tolerance
I would appreciate any info
Thanks
Adrian
October 06, 2011 02:23PM
They ship a 3mm rig but I think it should be able to make it work (with parts) with 1.75mm, as long as the Bowden setup is ok with it.
I continue to be unconvinced that 3mm vs 1.75mm makes any real difference for +99% of us..
> max tolerance
That's a reeeeally small number. I'm not sure any FDM-type machine, home or commercial, can promise doing that on a regular & repeatable basis.
October 06, 2011 05:01PM
At best you will get within .1mm per 25mm on a regular basis over a variety of parts, not counting blobbing.
They only ship with 3mm at the moment. I'm not sure if the diameter really matters much.
Thanks for the answers. Anyone has actual experience on both sizes? if 1,75mm has no significant difference with 3mm, why is makerbot and others offering this now?
October 06, 2011 10:54PM
I don't.
In theory, 1.75mm is more consistantly sized while a spool of 3mm can vary in diameter more.. Maybe it's 2.85mm in some parts and 2.90 or 2.82 in others while 1.75 sticks pretty close to 1.75. I don't know that anybody's actually tested this but I believe it.
Also, since you get less volume per extruder step with 1.75, you should be able to do finer extruder control. If you do one step (or microstep.. whatever) with 3mm, you'll get like 3x as much volume as with one step of 1.75. This sounds great but I don't think anybody in this crowd actually has a machine that can benefit from such added resolution on the extruder; we're talking tiny, tiny numbers here - numbers smaller than the tolerances of the rest of the machine.
I haven't seen them mention why it's better but haven't really looked either...
October 06, 2011 10:59PM
MakerBot is offering it because it allows for smaller extruders driven by smaller motors. It makes multi-extruder setups easier.
Check out www.PowerDrive.com for a wide selection of timing pullys and belts.
