Limitations and work arounds for Stratasys heated build chamber patent May 22, 2018 11:35PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 01:19AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 01:33AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 02:10AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 04:37AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 08:27AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 10:44AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 06:49PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 10:04PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 23, 2018 10:29PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 02:45AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 04:34AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 09:53AM |
I'm currently designing a personal printer that is pretty much a straight ripoff of their patent. The original mechanism is actually fairly clever, although I suspect that it would have been discovered by hobbyists had it not been developed by Stratasys.
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 11:09AM |
Bill Clark
Have you given any thought to what type of material or a source for the accordion thermal barrier separating the motion system from the chamber? I'm designing a similar machine.
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 12:52PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 01:58PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 02:43PM |
Bill Clark
Fortunately I do have access to a 900MC to study and they do use a cellular type barrier but don't know the material. I plan to run chamber temps over 200c as they do to print Ultem 1010
Re: Limitations and work arounds for Stratasys heated build chamber patent May 24, 2018 03:44PM |
Bill Clark
Re: Limitations and work arounds for Stratasys heated build chamber patent May 25, 2018 11:04AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 25, 2018 11:44AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent May 28, 2018 07:31PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 04, 2018 12:36PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 14, 2018 03:08AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 14, 2018 09:46AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 14, 2018 08:57PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 28, 2018 11:46PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 29, 2018 08:53AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 29, 2018 10:10AM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 29, 2018 12:12PM |
Re: Limitations and work arounds for Stratasys heated build chamber patent June 29, 2018 12:21PM |
Agreed but for us folks without a team of lawyers its nice to know that there's less chance (even it was already a remote chance) of them sending you a cease and disist after investing effort in to our machines wether we plan on marketing them or not. By the time I'm finished with this latest one I will have 1000's of dollars and at least a few hundred hours invested. Just helps put the mind at easeQuote
Roberts_Clif
If 3D Printers have been around sense. The first 3D printer ever created in 1983.
And heat chambers were then common knowledge before this patent, any heat chamber patent in itself violates the patent laws.
