Motors Rattling with new belts May 31, 2018 08:08AM |
Re: Motors Rattling with new belts May 31, 2018 06:21PM |
Re: Motors Rattling with new belts May 31, 2018 06:43PM |
Trakyan
Maybe you over tightened the belts? Or the new belt clamps are causing some slight misalignment (the effect of this would be worse at the ends of your travel which is what you're seeing).
The simple answer to your question is to go back to what worked.
Re: Motors Rattling with new belts June 01, 2018 01:23AM |
Re: Motors Rattling with new belts June 01, 2018 03:35AM |
Re: Motors Rattling with new belts June 01, 2018 04:21AM |
Re: Motors Rattling with new belts June 01, 2018 06:15AM |
Trakyan
Did you change anything that could have shifted your rails? Moved/reassembled/tweaked the frame, rail mounts etc. You could have out of parallel rails causing problems with binding. The y axis would be more prone to this I reckon and that matches up with what you're seeing.
