J-Head Mk 12 High Temperature Development June 05, 2018 10:48AM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 12:55PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 01:14PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 03:51PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 04:00PM |
MechaBits
But a Volcano heatblock is only $1, Looks more like a copy of a cheap chinese copy of your Jhead - 1
Re: J-Head Mk 12 High Temperature Development June 05, 2018 04:23PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 04:32PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 04:35PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 04:59PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 05:01PM |
jinx
will the Mk12 have the grub screws holding the heat break into the heat sink ( think that a nice feature to bring in from the hexagon).
NO heat break! kind of hoping to see a chimera style break in the design
Re: J-Head Mk 12 High Temperature Development June 05, 2018 05:06PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 05:18PM |
Re: J-Head Mk 12 High Temperature Development June 05, 2018 06:52PM |
Re: J-Head Mk 12 High Temperature Development June 06, 2018 03:45AM |
Re: J-Head Mk 12 High Temperature Development June 06, 2018 05:47PM |
Trakyan
0.25 mm walls and a set screw to hold it in place? You'd need to be a surgeon to assemble this thing without crushing it. Also, that's a tiny heatsink, how effective is it and what fan will you use to cool it?
Re: J-Head Mk 12 High Temperature Development June 06, 2018 08:41PM |
Re: J-Head Mk 12 High Temperature Development June 06, 2018 09:23PM |
Re: J-Head Mk 12 High Temperature Development June 20, 2018 01:59PM |
Re: J-Head Mk 12 High Temperature Development June 20, 2018 03:09PM |
reifsnyderb
Static testing continues with the new J-Head. There was only one failure. It failed to jam with PLA.
Re: J-Head Mk 12 High Temperature Development June 20, 2018 03:22PM |
dc42
reifsnyderb
How much retraction did you use, and what length Bowden tube (if any) does your test setup have?
Re: J-Head Mk 12 High Temperature Development June 20, 2018 04:52PM |
reifsnyderb
The heat break section is 2mm. I tried 2mm retraction and 4mm retraction. No problems. The bowden tube is about a meter long.
Re: J-Head Mk 12 High Temperature Development June 20, 2018 05:16PM |
dc42
reifsnyderb
With a 1m Bowden tube, my guess is that none of that 4mm retraction at the extruder will actually reach the hot end. My experience is that you need retraction of almost 1% of the length of the Bowden tube just to take up the filament slack in the tube, before retraction actually happens at the extruder. A little less with high-quality PTFE tube such as Capricorn. So with a 1m Bowden tube I would expect you to need around 10mm to 11mm retraction to ensure that enough retraction occurs at the hot end to avoid leaving blobs at the start of travel moves.
Re: J-Head Mk 12 High Temperature Development June 28, 2018 04:38PM |
Re: J-Head Mk 12 High Temperature Development June 29, 2018 03:59AM |
Re: J-Head Mk 12 High Temperature Development June 29, 2018 06:33PM |
