Toward the Graal : Ultra-light extrusion
Posted by M_Xeno
June 12, 2018 10:41AM
Hi, everybody!
All printers have an interest in light extrusion heads, especially deltas.
And we all know that pushing the filament as close as possible to the fusion zone, i.e. Direct Drive, is better.
And if the extruder could be a Bondtech, with two symmetrical hobbed gears, that would be perfect!
And also with a water-cooled Hot-End, but simple, not a gas plant...
Would you like to have all this in a 32g set? Yes, 32g, not 320g!
More explanations on my recently added page on the HackaDay website:
[hackaday.io]
This is part of my project for the delta robot Zatsit, quoted here, but on another subforum (This might interest you too!)
[reprap.org]
Re: Toward the Graal : Ultra-light extrusion
June 12, 2018 12:45PM
Wow, that's cool!
The drive gears look huge, what's the e-steps/mm you can achive with that worm gear?
June 12, 2018 01:05PM
@o_lampe
The drive gears are big, as to limit stress and deformation of the filament. This has no effect on the e-steps/mm value: with a worm drive, hobbed gears advance by one pitch of the worm each turn, regardless of their diameter. Here, about 1,5mm/ revolution, a quite good resolution.
June 13, 2018 01:16AM
I'm guessing you use a flex shaft ala flex3drive/zesty? Pretty cool design. Any idea what it would weigh if adapted to an air cooled system and how easy would it be to change hotend?
Also, great job on your delta, neat concept and execution. How well do the flexure hinges hold up over time?
June 13, 2018 02:25AM
M_Xeno
@o_lampe
The reason, why other worm driven extruders use a big gear ratio is: they can pick a thinner/lighter and more flexible flex-shaft.
In your case this isn't true and the stiffness of the cable has a bigger negative influence. Why not add a second gear stage and advance to a better suited drive cable?
Direct drive with a small pancake stepper would then work, too.
June 13, 2018 08:26AM
What does it weigh with the drive cable? A lot of these drive cable systems forget to mention that, and I think it is quite important as it is still another element the gantry has to move with.
June 13, 2018 09:08AM
@o_lampe
Wrong : Flex3drive, Zesty Nimble and my setup use about the same ratio, for the same reasons (advance of the filament = worm pitch), and we all use a ~3mm flexible shaft, the smallest currently available.
I did try to use a second stage of gears, to be able to run a smaller motor, but then the problem is with pressure advance : the speed variations asked to the motor are way too high, and step losses occur, even without any back-pressure.
The gear ratio of the setup shown here is already quite high (1,5mm/turn is 4800 steps/mm with a 1.8° stepper, and x16 microstepping). Problems already occurs with not well suited steppers, i.e. too high impedance and inertia.
Edited 1 time(s). Last edit at 06/13/2018 09:37AM by M_Xeno.
June 13, 2018 09:35AM
@Origamib
You're right, and that's a good question : available flexible shaft have a quite high linear mass.
For my prototype, I used only the core of the flexible shaft, and I replaced the sheath by another lighter one, of my manufacture.
But above all, I installed the stepper motor on a gimballed support, in a flystruder position (suspended between the three carriages), so that the length of the flexible shaft is only 12 cm. Under these conditions, the inertia, and parasitic forces, due to the flexible shaft are without appreciable consequence.
However, as when I use a flystruder with a bowden tube, I have to reduce the maximum speed along the Z axis to 500mm/s instead of the usual 600mm/s, because of the mass of the stepper. X and Y are still 600mm/s, so, no consequence either.
June 13, 2018 09:44AM
Where do you get your gears? I'd love to make something like this but I have a terrible time sourcing gearing.
Edited 1 time(s). Last edit at 06/13/2018 09:49AM by warbunniex.
June 13, 2018 10:10AM
@Trakyan
Replacing this compact and lightweight water-cooled Hot-End with a classic and bulky 60g air-cooled solution would be a really weird idea! ;-)
The hot-End presented here really only has advantages, and remains compatible with all the standard stuff (nozzles, cartridges, etc...)
But if you really want that, it must be possible. You will need to make the adapter. The extrusion mechanism alone weighs 12g...
If you wanted to talk about cooling printed objects, Zatsit offers an excellent solution, very powerful, and here too ultra-light.
Give a look to these links
www.zatsit.fr
[hackaday.io]
You will have detailed responses to your questions, about durability, Hot-End exchange, etc.
June 13, 2018 08:09PM
I ask about switching to an air cooled hotend as there is a bit more hassle with a water cooled system.
June 14, 2018 02:46AM
@Trakyan
I don't quite understand what hassle you' re talking about.
I still have air-cooled Hot Ends, which I used at the beginning of the Zatsit project, before I developed the solution with water. I can replace them in a few seconds, if I feel like it, and this will not change any of the printer's other functions (cooling parts, extrusion, etc...). The design of Zatsit is such that all effectors are interchangeable, and are just attached with three screws.
The only hassle will be that it will be necessary to purge the water circuit, by blowing inside, before disconnecting it, just as when one wants to pass from a use as a 3D printer, to a use as a generic robot.
I'm guessing you haven't seen the videos where all this is explained. On the whole, it's very simple...
Edited 1 time(s). Last edit at 06/14/2018 02:56AM by M_Xeno.
June 14, 2018 04:42AM
It's simple but it adds another step in the process. Plus you need to add a water reservoir which needs to be changed regularly and a pump which is usually noisier than a fan. I'm not saying a water cooled system is a bad idea, I just personally prefer an air cooled system for the slight advantage in simplicity and maintenance.
June 14, 2018 06:24AM
I won't try to change your opinion, but my experience over two years contradicts your assertions: the submersible aquarium pump is incomparably quieter and also much more reliable over time than any DC fan (and I've tried many!). With a drop of hypochlorite in the water, there's no reason to change it. Seeing air cooling as simpler is, IMHO, simply the habit of seeing it everywhere as the standard solution.
Edited 1 time(s). Last edit at 06/14/2018 06:26AM by M_Xeno.
June 16, 2018 09:24PM
I love the design, so are your plans to open source this design or bring it to market in some form?
June 17, 2018 05:40AM
@obelisk79
There will soon be a Kickstarter campaign for the Zatsit kit (see www.zatsit.fr), but I don't think I would have time to integrate this extruder, which still requires optimization studies, and especially, for mass production. The association of a POM pinion, and a metal hobbed gear, must be simplified, it is much too complicated to produce in series.
But it will be done, because I think there is a market for such an ultra-light extruder.
May 06, 2019 09:14PM
Any news on bringing this promising extruder to market?
May 14, 2019 10:23AM
I never have time to test my work it seems but have you tried out this flex shaft? [www.mhz-powerboats.com]
It's 2.2mm instead of 3 something. Should be a little less weight & a bit more flexible.
May 19, 2019 09:30PM
this could work as a flex shaft [www.ebay.co.uk]
[mechabits.co.uk]
