Plastic start to ooze heavily when heating up.
June 16, 2018 06:03PM
I have a strange problem that I dont have even on my bowden delta. On my FLSUN i3 Plus I installed E3D V6 clone and extruder directly above it, so direct extrusion. But when I heat nozzle up to about 190C plastic starts to ooze out and wont stop for minutes. Even if I retract 3-4 mm there is still plastic coming out. I have checked, upper part of V6 print head, radiator, is room temperature to tuch, I have 40x40x20 fan blowing on it.Heat break and nozzle are tightly screwed. What can cause it?
Re: Plastic start to ooze heavily when heating up.
June 17, 2018 01:08AM
Is there a gap between heaterblock and heatsink?
June 17, 2018 03:25AM
Yes, about 2 mm gap.
June 17, 2018 05:00AM
He means is the plastic oozing out of the nozzle or from between the nozzle and the heat block.
June 17, 2018 06:38AM
which thermistor been selected in F/ware.
June 17, 2018 07:33PM
No, plastic is going out from nozzle hole, from where it should. But too much. On my delta when nozzle is heated up there is about an inch of plastic going out due to gravity and ect, but here it just goes and goes for 5-7 inches. I checked temperature using water (dont have ir heat gun), it boils off is I tuch heater block with wet brush at 100-105 degree set.
