i have a prusa einsy running marlin bug fix for my tmc drivers and it will start a print but sends mintemp error after a few layers. the error is for the bed but i have tried to disable thermal runaway in config but it still triggers. and i have adjusted the hysteresis to 5 and it is only about 2c off. i just put a new thermistor on the bed yesterday. i though it may be a loose connection but it fails in the same spot every time. about 2mins after the first move. and line 463 in gcode file. so this tells me it not a wiring issue. what are my other option for why its doing this?
current firmware - [
www.dropbox.com]
edit- i have tried a different stl and the error is always triggered at the end of the 4th layer.
Edited 4 time(s). Last edit at 07/10/2018 04:30AM by deltajegga.
